Author Topic: Want a upgraded Anti Roll Bar LOOK HERE  (Read 22681 times)
Offline Steve_PD
« on: 11 March 2012, 21:29 »
So you've lowered your car and now the driveshaft is rubbing on the Anit Roll Bar.
These are the recommended arb's:
Mk4 Golf R32 - 1J0411305AF (23mm)
Mk4 Golf 4 motion - part number and size needed ....
Mk1 Audi tt - part number and size needed ....
Audi S3 - 1J0411305AA (19mm)
Skoda Octavia VRS - 1J0411305AD
Seat Leon Cupra R (MK1)
Whiteline ARB
All the above go under the drive shaft and WILL not rub regardless or how low you go. You may need to fit adjustable drop links as well.
The likes of the Eibach, H&R, FK ARB or any other which loops over the top of the driveshaft will only give you a little clearance and depending on how low you go may rub.
Any other info you think will be helpful please post and we'll add it.
« Last Edit: 12 March 2012, 19:44 by Steve_PD »
Offline mcgee9t2
Re: Want a upgraded Anti Roll Bar LOOK HERE
« Reply #1 on: 12 March 2012, 11:34 »
"Part number: 1J0411305AD off me is £70 Octavia vRS pre-facelift anti roll bar :-) RRP is about 60 odd quid + VAT"
thats off a mate who works at skoda. so unless you have a mate that works there you will proberbly get charged a bit more. but 70 is a rough price
Offline AaronGS
« Reply #2 on: 21 April 2012, 07:43 »
I use the Neuspeed ARB. It does go over the drive shaft but I have never had rubbing issues, even when low. Just another option, maybe.
http://www.neuspeed-europe.com/product.php/255/345
Offline 1.6mk4GOLF16v
« Reply #3 on: 03 June 2012, 14:30 »
what do the 2 letters AD at the end of the part number mean?
ive found a arb with the same part number except it has the letter E instead of AD  :undecided:
also what does the 23mm and 19mm in the first post represent? arm diameter or..?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline Steve_PD
« Reply #4 on: 03 June 2012, 18:08 »
As long as the ARB is off a mk1 octavia it will fit.
Its the diameter of the ARB
« Reply #5 on: 04 June 2012, 14:27 »
so would i need the 23mm or 19mm diameter?  :embarassed:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline Chris620
« Reply #6 on: 07 December 2013, 01:00 »
Hi guys I just brought an s3 arb and when I came to fit it I found that it was an inch maybe more to short and wouldn't reach to when the drop links hang down like I'm busing the standerd golf link that are 105mm so we're have I gone wrong lol please help as this rubing is driving me crazy lol
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 26 December 2013, 21:15 »
You need to use adjustable drop links plus add a spacer
Offline gavsgti
« Reply #8 on: 28 January 2015, 18:32 »
just got my car back from been lowered as ive been to busy with work to do it myself and it seems im having the proberlem of on full lock the drive shafts are catching the arb which has infact snapped it or the bush
just searched and found this thread and was wondering if i was to get the Seat Leon Cupra R (MK1) arb would i also need the adjustable drop links and how easy are they to fit like to have a go myself ?
thanks in advance  :smiley:
Offline gavsgti
« Reply #9 on: 28 January 2015, 20:16 »
seems its the drop link thats snapped not the arb
so would adjustable drop links fix this ?
only after a temp fix atm as ill have to set the coilovers up properly when ive refurbed the 18" wheels i got
then will see if i need to get another arb but would like to know if the above arb would need the adjustable drop links aswell if poss
thanks again
gav
