Author Topic: What's the best 1.8t engine to go for?  (Read 5442 times)
Offline xtetx
« on: 27 April 2012, 22:24 »
What engine code should I be looking for? :)
Offline johnnyvr6
  • golf v6 4motion soon to be 1.8t'd
Re: What's the best 1.8t engine to go for?
« Reply #1 on: 27 April 2012, 22:29 »
agu
Offline rockmonkey69
« Reply #2 on: 27 April 2012, 22:50 »
What throttle body have you got now? Is it cable driven or wire (electronic)?
No point going through the effort of swapping from one to the other.
If your asking which engine is best throttle body and ancillaries aside then it depends, what sort of power are you aiming for? There's no one engine code that's best for every scenario.
Offline cullygti
« Reply #3 on: 27 April 2012, 23:54 »
erm bam lol
« Reply #4 on: 27 April 2012, 23:55 »
Auq if you can find one :afro:
« Reply #5 on: 28 April 2012, 00:07 »
I would say no to Bam or Auq being the ultimate 1.8t, it's a small port head and if one was to try build a quarter mile drag car they would have no use for the standard Bam internals, VVT, standard management or k04 and they would want a large port head instead.
As I said, no one engine code is absolutely superior in every scenario. I do not believe the above scenario is true of the OP, that's why I would suggest he just chooses the engine with the same type of throttle body as what his one is now.
« Last Edit: 28 April 2012, 00:15 by rockmonkey69 »
Offline cullygti
« Reply #6 on: 28 April 2012, 00:31 »
and how can you compare a 1.6 to a 1.8t no matter what the throttle theres no comparison
« Reply #7 on: 28 April 2012, 00:51 »
Electronic or cable. An average person doing the conversion on their drive does not want to buy a 1.8t to find it is drive by wire (electronic) when their car originally came with cable operated throttle body. It's not a case of just swapping over the throttle bodies.
Offline xtetx
« Reply #8 on: 28 April 2012, 08:10 »
It has electronic as I found out when I asked aRd to see if I could have cruise in. Not sure at what power really. 300 would be awesome, just want more power If I'm honest. Something I can work on and build up to be a monster
Offline gti_boz
« Reply #9 on: 28 April 2012, 08:49 »
BAM AMK both both forge bottom ends and cranks big injectors but have VVT.. Or if on a budget.. And my prefferd pne..AGU they have forge bottom end and bigger valves smaller turbo than the other two but can soon be changed
« Last Edit: 28 April 2012, 08:51 by gti_boz »
