Author Topic: What's the best 1.8t engine to go for?  (Read 5419 times)
Offline gti_boz
Re: What's the best 1.8t engine to go for?
« Reply #10 on: 28 April 2012, 08:56 »
So you already have a golf 1.8t? What engine is it? You could go down the simple way which I have on my daily and it's awesome..
K04-001 turbo (straight fit ment)
Saab injectors
3" turbo back exhaust
Front mount
007 diverter
3" MAF
3" TIP
Cc tuning custom map
Goes really well.. I've also got a meth injection kit to fit so should be even better after that
Offline shaft69
« Reply #11 on: 28 April 2012, 09:07 »
Saab injectors
Front mount
007 diverter
3" MAF
3" TIP
Whats yours running at??
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline xtetx
« Reply #12 on: 28 April 2012, 09:35 »
No I have a 1.6 dude, looking to convert
Offline johnnyvr6
  • golf v6 4motion soon to be 1.8t'd
« Reply #13 on: 28 April 2012, 09:49 »
dont go bam to expensive get a agu for 200-300 then buy a ko4 turbo for alot less than a bam
Offline barrym381
« Reply #14 on: 28 April 2012, 10:06 »
as said mate best startin with a turbo save you a lot of f**kin about  :smiley:
Offline rockmonkey69
« Reply #15 on: 28 April 2012, 10:11 »
BAM AMK both both forge bottom ends and cranks big injectors but have VVT.. Or if on a budget.. And my prefferd pne..AGU they have forge bottom end and bigger valves smaller turbo than the other two but can soon be changed
All the 1.8t have the same size valves although the exhaust valves on the Bam are made of inferior material. It's only the inlet ports and valve throats which are enlarged on the agu.
For 300bhp you may be better off on an aum, it will give a better power band and torque than on the agu, what's more you won't be near the limit of flow capability for the small port head don't worry. Although a few my mates run over 300bhp and similar torque on a standard aum/auq you may like other 1.8t owners just want to drop in forged rods and sleep easy. As you already have an electronic throttle body you want to stick to a 1.8t with an electronic throttle body (me7.5 management) it's a more straight forward conversion and much nicer to map than the me3 counterpart
You should go for Bam or Aum but you do pay a premium for the Bam, Bam pistons are slightly lower compression so will be nice if your sticking to small turbo for the 300bhp and will make the mappers life that much easier but generally speaking if all you want is 300 bhp you will have enough headroom on the higher compression Aum pistons. Naturally the higher compression pistons of the aum are nice if you decide to go for a slightly larger turbo, you will find that the higher compression pistons reduce transient lag.
« Last Edit: 28 April 2012, 10:14 by rockmonkey69 »
Offline shaft69
« Reply #16 on: 28 April 2012, 10:36 »
What bhp isyours running at with mods?? Looking fit hybrid turbo to mine be bit more aggressive tho than 001 turbo, i'm running meth inj spot on upgrade.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline gti_boz
« Reply #17 on: 28 April 2012, 11:17 »
I need to get it on some difrent rollers.. The chassis kept touching the floor when lowering it down on the rollers.. Pluss by the time he got the Saab Injectors mapped in he said I was running really hot..
But.. It got 210bhp and 249 lbsft holds the torque through most of the revs.. Pulls really well quicker than my mates scoob and mate mk1 focus rs and his is running 240
Really impressed with it.. Was gutted about the figures but when I drove it it soon changed.. Feels awesome, like I said I've still got the meth kit to fit yet also :)
Offline shaft69
« Reply #18 on: 28 April 2012, 12:08 »
« Last Edit: 28 April 2012, 13:55 by shaft69 »
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Rhyso
« Reply #19 on: 28 April 2012, 12:17 »
Buy a car with 300bhp or a MK4 with a 1.8T
A few years ago, a conversion would be a cheap way of doing things but you can pick up MK4's for so little these days its not worth it.
Add to the fact you'll need literally EVERYTHING from the front end of the 1.8T from driveshafts, to hubs, anti-roll bar, coolant pipes etc etc
My mate Dai converted his 2.0 and needed all the above plus more.  He was lucky in that he bought a donor vehicle, was handy with a spanner or two, and had a couple of people to help out  :wink:  He made a few quid by breaking the donor vehicle.
Converting a 1.6 will be just as hard, if not harder and is not worth the hassle IMO
