Author Topic: time for the engine to go.  (Read 5408 times)
Offline off_the_cuff
« on: 26 April 2012, 15:34 »
so the time has come to give up trying to revive my 8v.
I picked up a tuned 16v engine for a gd price so thats going in :D
does any1 know if theres anything that might cause a problem during the swap?
got the complete engine, full running gear, full loom and clocks.
do i need a new manifold?
Offline tweed
Re: time for the engine to go.
« Reply #1 on: 26 April 2012, 15:58 »
You need ecu and transponder too. Also need 16v front engine mount and a 16v complete exhaust system.
8v is 50mm
16v is 55mm
« Reply #2 on: 26 April 2012, 16:23 »
whats a transponder? :s i have the ecu and engine mounts lol
my cars got a miltek exhaust system will that do? the only standard part is manifold and downpipe
Offline Dmonday
« Reply #3 on: 26 April 2012, 17:29 »
Aren't the 8v's cable clutch and 16v's hydraulic?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #4 on: 26 April 2012, 17:31 »
yep :wink:
but can still work, we did it with the 16v car i robbed my bits from to convert mine to hydro, we even fitted the 8v box to the abf
« Last Edit: 26 April 2012, 17:34 by F17BAD »
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Dmonday
« Reply #5 on: 26 April 2012, 17:35 »
yep :wink:
Didn't know you could do that, sweet :)
« Reply #6 on: 26 April 2012, 17:37 »
whats the transpoder?
Offline Dmonday
« Reply #7 on: 26 April 2012, 17:39 »
Little black box under the dash, behind the clocks i believe, has two wires going into it :)
« Reply #8 on: 26 April 2012, 17:40 »
is that the box that links to the chip in the key for alarm/ immob?
Offline F17BAD
« Reply #9 on: 26 April 2012, 17:41 »
yeah bit of a pain if your robbing the bits off the 16 valve car and replacing the 8v bits
but if your car is a 8v you could swap out the lump and mate it up to the 8v box using 8v flywheel, and bingo
to run 16 box and hydro bits he is gonna need all hydro parts and gear linkages plus the correct mount brackets (will still need this for drivers rear side (thats bracket not mount)
driveshafts are all ok
needs chip from donor key too to work with transponder unless ECU has been defeated
