Author Topic: time for the engine to go.  (Read 5420 times)
Offline off_the_cuff
Re: time for the engine to go.
« Reply #10 on: 26 April 2012, 17:43 »
its got an 8v box already on it so should be sweet :D
not sure about the transponder, will need to look. if i dont have it can i just buy a transponder and chip?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #11 on: 26 April 2012, 17:45 »
need the one that was with the ECU mate, where did u get the engine ? whats it come out of ?
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #12 on: 26 April 2012, 18:10 »
guy had it in an estate with the intention of putting it in a mk1 golf, as far as i know i bought everything to do the swap :S
so i may need a new ecu aswell?
Offline CJA321
« Reply #13 on: 26 April 2012, 18:38 »
Im looking at replacing the 8v for a valver also. Do you need new radiator and hoses etc?
Offline F17BAD
« Reply #14 on: 26 April 2012, 19:17 »
Radiator will work fine, al hose locations same, will need the engine hoses tho so make sure they come with the engine unless u want to buy all new
@ off the cuff, you will deffo need the ECU
Offline Ess_Three
« Reply #15 on: 26 April 2012, 19:53 »
No you won't...
You can adapt the Mk3 ECU & Immobiliser using VCDS (VAG Com)...you go into the ECU/Immobiliser modules and into Adaptation.
Go to the 'Engine' module.
Select 'Adaptation'
Press 'Read'
Wait...
Press 'Save'
Go to the 'Immobiliser' module.
Select 'Adaptation'
Press 'Read'
Wait...
Press 'Save'
That's it...
You will need an immobiliser module, ignition switch ring and matching key if you are using the immobiliser type ECU....and of course, you will need the diagnostics hooked up and working.
I've had 3 different ECUs in my car, and re-coded the ECU/immobiliser every time...takes 30 seconds.
..but gaining motorcycles.
« Reply #16 on: 26 April 2012, 21:24 »
Just making sure, is the 16V lump is out of a mk3 ?
« Reply #17 on: 26 April 2012, 22:15 »
Yeah its from a mk3. Lol
« Reply #18 on: 26 April 2012, 23:59 »
Thats good then :afro:
« Reply #19 on: 27 April 2012, 00:09 »
can i not just swap the 8v ecu for 16v then reprogram it? instead of tracking down a new transponder and chip?
