Author Topic: Mk3 stereo problem  (Read 5516 times)
Offline Willo
Mk3 stereo problem
« on: 22 April 2012, 13:26 »
Every time I turn of the ignition in my mk 3 the stereo loses all the stations I've tuned in its an aftermarket pioneer stereo
Will
Offline Len
Re: Mk3 stereo problem
« Reply #1 on: 22 April 2012, 13:30 »
Connected up wrong!
Need to use the remote
www.sas.org.uk
www.the-ace.org.uk
Offline Willo
« Reply #2 on: 22 April 2012, 13:47 »
The remote cable is wired to the amp to turn on the amp like in all my other cars
Offline shelaghmk3gti
« Reply #3 on: 22 April 2012, 18:06 »
Lens right, same thing in mine,theres 2 wires that need swapping... ill go and have a look at my thread and see if i can tell yu which ones.. its a royal pain  :laugh:
« Reply #4 on: 22 April 2012, 18:13 »
this is the reply i got from Dogbot when i asked about the same problem
sheilagh,
you need to swap on the black plug,
small brown with red trace = ignition live
large red with white trace = permanent live
swap those two & yours will work perfectly, & remember all your stations & cd positions the lot,
basically, your radio's memorey is being wiped when you take out the key, it needs permamnt live to remember these things
Offline Willo
« Reply #5 on: 22 April 2012, 21:59 »
How did u swap them ?? Just cut them or do they pull out ?
« Reply #6 on: 22 April 2012, 22:17 »
eerrr actually i havent got around to doing it yet  :grin:
inbox dogbot im sure he'dbe more than happy to advise x
Offline Len
« Reply #7 on: 23 April 2012, 12:39 »
Well thats what ya done wrong! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline Dogbot
« Reply #8 on: 23 April 2012, 14:46 »
the blue remote cable going to the amp is perfectly correct it powers up the amp,
as sheliagh has posted my reply i just need to add that you can either cut & solder the joins & heatshrink them, or you can crimp on connectors, its your choice, but for christs sake dont do what halfords do, which is cut, twist then tape, your dealing with a permananet live..... it needs to be finished up correctly..
most new iso adapters come with bullet connectors so you can do this wothout cutting just depends on which unit you have my new pioneer had the bullet connectors on but my previous jvc didnt, hence why i cut & changed my loom,
the remote output is there for output power souce to amp, not to power memory...
dont work for halfords do you :lipsrsealed: :grin: :laugh: :grin: :cool: :wink:
« Last Edit: 23 April 2012, 14:55 by Dogbot »
Offline trog_nfs
« Reply #9 on: 23 April 2012, 16:38 »
I don't think those comments are very fair about halfords. Myself and my colleagues where I work would NEVER cut strip and twist
