Author Topic: eibach anti rollbars fitted,sorted arb catching,but rumbling still harcornering  (Read 1389 times)
Offline rench
got eibach anti roll bars fitted today with adjustable drop links but drives side still catching over bumps in the road. my car has standard anni shocks with polo top mounts so its not stupid low. id say about 40mm ish.
wat do i need to do to stop this, the drop links are set short do i go longer or take the nut out so they go even shorter?
Sorted this now, cut drop links Down that's sorted the arb catching but I'm still getting a rumberling when cornering hard sounds like its from pass side any ideas?
« Last Edit: 22 April 2012, 17:07 by rench »
Offline Procomp
Re: eibach anti rollbars fitted, front still catching
« Reply #1 on: 20 April 2012, 22:12 »
Rench
I've got the same ARB fitted and even with short adjustable drop links, i had the same issue myself.  The only way I've been able to do a fix was to have the drop links cut down even more.  This involved cutting the stem at the bottom of the drop link (not the threaded top end), cutting off to the bottom of the threaded end and then welding it back up 'up side down' so you have the original threaded end at the bottom of the drop link to reconnect the two parts.
I now have better clearance and only occasionally, do I get a rub.  With the shape of the rollbar, you have basically to reduce the shorted drop link even further, to get the optimum clearance on the ARB.  There is a thread somewhere on here where somebody else has done the same, which is what I followed.
Gregg
Offline cullygti
damn i need adjustable drop links couldnt you just cut them down and re tap the with a tap and die set instead of welding etc
Offline rench
so ive not realy gained anything from having the front arb changed? was knocking before with standard and maybe worse now lol
Offline Procomp
Rench
I have to say I was a little dissappointed myself that I had to do the additional work on the shorted droplinks.  Whislt the ARB can go lower because it has a bigger arch in it, I think it's more designed for a slight drop and improvement is ride because of increase size etc.
May be the right solution if you're going low, is to fitt a 4motion (TT I think also) ARB, as these go under the driveshaft.
hmmmm.......... :undecided:
Offline rench
pritty sh!t then, im not even that low. wish they had told me this when i ordered them, would gone for some other if i new it wouldnt solve my driveshaft problem.
Offline Steve_PD
Should have read this before buying the Eibach one :lipsrsealed:
http://www.golfgtiforum.co.uk/index.php?topic=224905.0
Offline rench
im not going stupid low only 40-50mm, going to give company a call tomrrow and see what they have to say
Offline Dave_IOW
I have them fitted and this is spot on...
Rench
The thread i think you are talking about was mine and Sib's, we cut our droplinks down to 3 1/2 inch center to center and allowed us a 60mm (ish) drop without any rubbing atall..
It is a pain that you have to modify but it does work..
I've explained this all to Rench in PM's  :smiley:
If anyone else is interested, ill try to get some pictures or find the original thread.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline AaronGS
I have neuspeeds ARB.
No rubbing issues at all, aven when I was low, down near the bottom ot the koni coilovers.
Comes with adjustable droplinks too. Just seems easier all round, instead of cutting and welding etc. Not much help for you now, I know. Good luck with making it work!
