Author Topic: egr blank plates????  (Read 5093 times)
Offline coxy1980_123
  • start of the project
« on: 18 April 2012, 10:28 »
Hi has anyone tried the ebay egr blank plates on a mk 3 1.9tdi golf please? and when fitted do you need to remove any hoses etc??
« Last Edit: 18 April 2012, 18:14 by coxy1980_123 »
   SHES GETTIN THERE
Re: egr blank plates????
« Reply #1 on: 19 April 2012, 13:01 »
Bump help me
   SHES GETTIN THERE
« Reply #2 on: 19 April 2012, 19:47 »
ive read on another forum tha if you disconnect the hose goin to the egr and blank that off it has the same effect as deleting the egr is this the case?
   SHES GETTIN THERE
Offline archie837
« Reply #3 on: 19 April 2012, 21:04 »
Imagine so. Might be better off looking in the mk4 section as it's a more common mod than on the mk3 diesel.
Project longterm Airbanger.
PD150 Anni daily
« Reply #4 on: 19 April 2012, 21:22 »
ok ill take a look cheers.
   SHES GETTIN THERE
Offline gti gaz
« Reply #5 on: 20 April 2012, 08:09 »
Why bother it does not make that much diffrence
 Any one in cornwall lets sort more meets!!!!
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #6 on: 22 April 2012, 11:29 »
You can just disconnect the EGR,  If it has a needle lift sensor it will throw a code, but shouldn't effect it,  The only reason to blank the EGR is if its all gunked up and sticking open rather than closed.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #7 on: 22 April 2012, 15:52 »
i think it might be stickin open somtimes mate . if i did blank it do i just put the plates in ??
   SHES GETTIN THERE
Offline Rmachines
« Reply #8 on: 22 April 2012, 17:05 »
Fit the plates and block the vac hose,  I cant remember if there is a needle lift sensor though,  I guess not,  so just make sure the solenoid near the intake pipe is left plugged in but the hose is blocked off.   Otherwise you might end up with limp mode
« Reply #9 on: 23 April 2012, 21:26 »
nice 1 cheers mate . just got to work out which plates i need on ebay .  :smiley:
   SHES GETTIN THERE
