Author Topic: anyone know if there any good??  (Read 1321 times)
Offline wolfie1981
« on: 05 April 2012, 23:35 »
http://www.ebay.co.uk/itm/150732117943?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 any good??
they say there 2.25" what size de cat pipe would you need to fit this
« Last Edit: 05 April 2012, 23:55 by wolfie1981 »
Offline barrym381
Re: anyone know if there any good??
« Reply #1 on: 05 April 2012, 23:37 »
should be a straight fit
Offline golfyste
  • Project track car
« Reply #2 on: 06 April 2012, 09:50 »
I would say itmmthe diameter is a bit small you anna look for 2.75 really. An the size of the decat won't matter as the Flange should be the same size ( but preferably you want 3")  :cool:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 06 April 2012, 12:30 »
I think Blueflame/Miltek is 2.5" bore?
Offline palmtree
« Reply #4 on: 06 April 2012, 13:53 »
I thought the standard exhaust on a 1.8T is 2.25" anyway
Offline cullygti
« Reply #5 on: 06 April 2012, 13:56 »
i got one of these and had it modified to fit mine was a direct fit of the old system had the tips cut off a rewelded to fit a 4mo valance as they sat to low on standard valance thats the only problem with them really sounds nice and not to ott
« Last Edit: 06 April 2012, 13:59 by cullygti »
Offline cullygti
« Reply #6 on: 06 April 2012, 13:57 »
and standard system is 2.25  :smiley:
Offline wolfie1981
« Reply #7 on: 06 April 2012, 14:30 »
2.25 good to use then??
Offline dom
  • Back in a Mk4
« Reply #8 on: 06 April 2012, 14:34 »
Yeah, but you may as well go for a bigger diameter pipe if your upgrading the system....seems a little daft not to :undecided:
Offline nolandubholmes
« Reply #9 on: 06 April 2012, 19:09 »
U really should go for a 2.5 inch system or a 3 inch system that system will flow better as it will use free flow boxes that are straight through boxes using perf and wadding not chambered like standard systems but in reality a milltek or a custom exhaust you will benifit much more from it
aum no spec as no matter what i do il never be happy
