Author Topic: Windows have packed up!  (Read 2839 times)
Offline Michael
  • I love YaBB 1G - What the hell did I type here?
« on: 12 March 2012, 21:34 »
Hi.
I have a 1991 mk2 16v Golfy. It has OEM windows and they no longer work. I've checked number 53 relay by swapping it with the other 53 ( horn I think?) relay and still no joy. Are they fused elsewhere?
They don't click, don't light up, they just sit there!
Any thoughts please everyone?
Offline Jamtarts
Re: Windows have packed up!
« Reply #1 on: 12 March 2012, 21:52 »
I had a similar fault with my old Astra, I drill out the rivets on the winders, cleaned the winder mechanisms up (they were full of rubbish) and re rivetted them together, they worked fine after that.  It might not work on the Golf but it's maybe worth a look?
Offline Michael
« Reply #2 on: 12 March 2012, 22:03 »
Thanks JT.
That's a good call but I think it must be electrical as the switches don't even light up when the used to!
Still should clean out the mechs though, another job for the list!
Offline Jamtarts
« Reply #3 on: 12 March 2012, 22:10 »
Thanks JT.
thanks, hope you get them sorted :)
glove
« Reply #4 on: 13 March 2012, 17:42 »
« Last Edit: 22 April 2012, 00:32 by glove »
Offline Michael
« Reply #5 on: 13 March 2012, 18:37 »
Ah nice one. May well be that relay behind the console then! That's a job for tonight. Have tried the relay and fuse mentioned I think.
Cheers Glove, handy information.......
glove
« Reply #6 on: 13 March 2012, 18:51 »
« Last Edit: 22 April 2012, 00:31 by glove »
Offline Ktuludays
« Reply #7 on: 13 March 2012, 19:02 »
if both windows have stopped working then it has to be something that they share which is causing the fault!!
<br /><br />What don\'t kill ya, makes you more strong!
Offline Michael
« Reply #8 on: 13 March 2012, 20:26 »
You're right, it was!
Traced back the window loom from the console to the thick bunch of wires behind the fuse board. Checked each one to notice the main brown earth had come adrift from the earthing bus bar!
Result, connected it back on, ignition on and....I have windows again!
Thanks everyone and thanks Ktuludays for hinting in the right direction!
Happy happy joy joy.
glove
« Reply #9 on: 13 March 2012, 21:05 »
