Author Topic: Windows have packed up!  (Read 2840 times)
Offline Michael
  • I love YaBB 1G - What the hell did I type here?
Re: Windows have packed up!
« Reply #10 on: 13 March 2012, 22:09 »
Cheers Glove!
Has been one of those achievement evenings with Golfy.
Fitted an LED to the handbrake warning light, it had never worked.
Sorted the windows
Took apart the whole dash to fit my old clocks but this time got them straight and with all bulbs working!
Found a missing screw for the dash, now a lot more substantial.
Still loads to do but as you say, really gratifying to sort the issues and not pay someone else!
Cheers!
Offline devilscaff
  • allways up for alaugh
« Reply #11 on: 15 March 2012, 18:27 »
I have one window that will not work but when I press the button I can hear a faint noise comming from the motor so I no there is. power getting through.Is it possible to get stuck?
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #12 on: 15 March 2012, 18:40 »
Take off the door card and have a look.  If the motor turns but no window movement, could be a broken/jammed cable.
Over time the metal swarf from the cable, mixed with grease and dirt, can block up the guide tube and foul up the gear cog/worm gear in the motor assembly.
Offline devilscaff
« Reply #13 on: 15 March 2012, 18:50 »
ok thanks. Another job on the list
« Reply #14 on: 15 March 2012, 19:11 »
As long as the cable hasn't snapped (as mine did) it's repairable.
Offline devilscaff
« Reply #15 on: 16 March 2012, 18:01 »
cleaned out the runners,window now works a treat it was just stuck in the gunk, thanks
