Author Topic: Car seems slower after i fitted Forge 007p  (Read 4540 times)
Offline cullygti
Re: Car seems slower after i fitted Forge 007p
« Reply #10 on: 13 March 2012, 12:18 »
mine was lacking boost when first fitted i undone then done back up and was fine just luck me thinks  :grin:
Offline turbopete
« Reply #11 on: 13 March 2012, 12:23 »
Ill double check clips and if that doesnt work ill try a yellow spring, for the sake of £20. Cheers
Offline Big Tone
« Reply #12 on: 13 March 2012, 12:36 »
Do you have an air compressor?
Pressure test it to be sure.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline turbopete
« Reply #13 on: 13 March 2012, 12:49 »
Got a compressor yeah, How do i test it? Not much cop with this type of stuff.
Offline Big Tone
« Reply #14 on: 13 March 2012, 13:28 »
Do a bit of searching on here pal, basically you block off the boost tract at various points and pressurise it, any leakage you will hear/see ( if you are a tart like me and go round each joint with gas detector :grin:)
Wouldnt reccommend it though if you not confident, even at "low" pressures, you could damage the car or yourself if you dont do things correctly.
Offline harlemex
« Reply #15 on: 13 March 2012, 13:30 »
I was gonna get one of these, but now ive heard this, think ill stick with my baileys.  :shocked:
Offline Big Tone
« Reply #16 on: 13 March 2012, 13:36 »
 :huh:
Can't see forge making a "new and improved" dv, with its own inbuilt fault  :grin:
Saying that though, any successful users?
Offline DMcK
  • Red MK4 Golf 1.8T. Unmolested...Soon to change!
« Reply #17 on: 13 March 2012, 13:54 »
I've been thinking about getting one. Is a diverter valve the same as a dump valve? I was also told by 2 mechanics dump valves are no good for the engine and can cause problems. What you lot think?
Offline Big Tone
« Reply #18 on: 13 March 2012, 14:08 »
True.
read the sticky about dump and diverter valves. They different :laugh:
« Last Edit: 13 March 2012, 14:09 by Big Tone »
Offline DMcK
« Reply #19 on: 13 March 2012, 14:15 »
True.
What you think about the Forge 008 then? No go or approved? I just read the sticky quite a good read.  They say a must on a mapped engine. Mines not mapped...YET!
