Author Topic: Car seems slower after i fitted Forge 007p  (Read 4530 times)
Offline turbopete
« on: 12 March 2012, 13:12 »
Fitted a forge 007p but my car doesnt seem to have as much poke as it did with standard black one. Any ideas? thanks in advance.
Offline cullygti
Re: Car seems slower after i fitted Forge 007p
« Reply #1 on: 12 March 2012, 13:19 »
is the vacuum pipe corroded  :undecided:
Offline Ashmond
  • Money, b!tches And Boost
« Reply #2 on: 12 March 2012, 13:20 »
or have u split a pipe whilst fitting?
Offline turbopete
« Reply #3 on: 12 March 2012, 13:44 »
Put a new silicone pipe on the top of valve, couldnt see any split pipes.
Offline Toby
  • Car - less
« Reply #4 on: 12 March 2012, 13:59 »
u must have a boost leak, fitting a 007 wont make it anyy slower
Currently down under
Offline turbopete
« Reply #5 on: 13 March 2012, 08:00 »
Checked for leaks next to Valve but nothing noticeable. Did notice a hole in exhaust though, Could that make a difference?
Offline Big Tone
« Reply #6 on: 13 March 2012, 09:49 »
How did you "check for leaks?", done all jubilees up tight?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #7 on: 13 March 2012, 10:31 »
Is it mapped? What spring is in there if one at all?  :laugh:
Offline turbopete
« Reply #8 on: 13 March 2012, 11:45 »
Just looked for splits in the hoses i was working next too. Ill double check the clips tonight. Yes its mapped, got a green spring in. Seems to be lacking in torque more than anything.
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #9 on: 13 March 2012, 11:50 »
Try a yellow spring. Mine held boost better when I went from green to yellow.
Just a bit weird you say it happened after you fitted the 007p. So fingers pointing to that area.
