Author Topic: Can I use VW oil in Renault?  (Read 1791 times)
Offline stainesy
« on: 11 March 2012, 17:10 »
I have just got myself a family runaround. A Renault 52 plate Renault scenic 1.6 16v
It's low on oil so was gona top it back up. Anybody no what oil to use in one of these?
I have a load of oil left over from when I done an oil change in my mk3 golf gti 8v. Stuff I got from VW. Can't remner way it's called. Will that be ok to use?
Offline CJA321
Re: Can I use VW oil in Renault?
« Reply #1 on: 11 March 2012, 17:15 »
Yeah just bung it in if your topping up.
Just make sure you get correct oil when your changing it with a filter.
Offline The Mighty Elvi
  • I'm better than you today.
Offline JC
  • Back in the North.
« Reply #3 on: 11 March 2012, 17:57 »
 :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked:
Offline Dolly
« Reply #4 on: 11 March 2012, 18:20 »
did a clio recently it was 5w-30 fully. BUT it was a couple of years newer so maybe different engine
Offline CJA321
« Reply #5 on: 11 March 2012, 21:33 »
people use ASDA value oil for oil changes... topping up imo wont make a differance. Esp on an older higher milage engine, if it was turbo'd or diesel id of said something else  :rolleyes:
Offline justalex81
« Reply #6 on: 11 March 2012, 21:59 »
i'd say go for it. worst thing that can happen is you kill it. which means there's one less french sh1tmobile on the roads.
Offline Bellend
« Reply #7 on: 11 March 2012, 23:04 »
Lets be honest, if it's just low on the dipstick IIRC it's about half a litre.
If you are planning on doing a full change soon, it's far better then having it low.
However, both should be 10w-40 so it is the correct grade, always best to have the same make oil but the long and short of it is it will be fine.
Just think about servicing it with a new filter (cheap enough with the forum ECP discount. :wink:) soon. :)
Where all my moneys went.
Offline bored_Welsh_lad
« Reply #8 on: 12 March 2012, 07:13 »
How is it better than driving 5 mile to the nearest shop and getting THE CORRECT OIL!!! for his car? Jesus.. If hes driven it for this long with it low, another 5 miles aint going to be any worse than throwing the wrong grade oil in.
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline AudiA8Quattro
« Reply #9 on: 12 March 2012, 09:39 »
The OP doesn't even say what grade oil the car needs, and what grade he has got.
VW oil is fine to use in a Renault, if the grade is correct.
