Author Topic: got the car back and now im stumped (solved)  (Read 1939 times)
Offline 16valver dan
  • 1.8 20v turbo MK4 Golf
« on: 09 March 2012, 15:45 »
well origanally i was told the door had dropped on both passenger sides so they didnt open. but its stumped me after getting in through the boot (no remote and drivers lock not working) i realised if u pull either of the handles to the doors on the inside of the car the lock goes up put retracts when u release handle. and the in car unlock button only unlocks the drivers side and boot any ideas?
« Last Edit: 11 March 2012, 16:35 by 16valver dan »
il update the sig when i get a good photoshoot ;)
Re: got the car back and now im stumped
« Reply #1 on: 09 March 2012, 16:13 »
its asif the car is deadlocked on passenger side would disconnecting the battery reset it?
Offline bunj
  • www.bunjair.com
« Reply #2 on: 09 March 2012, 17:12 »
Sounds like you might have solenoid failure on both N/S doors??
A good mechanic or locksmith should have a lockout kit to use on the rods to open the doors.
MK4 GTi 1.8T, Black magic, stage one Jabba, Forge Split, filter, sportex race pipe, lowered 25mm.
PS3 network: raebuns
« Reply #3 on: 09 March 2012, 17:38 »
but why would it retract the lock pins when the hand from inside is released
Offline bunj
  • www.bunjair.com
« Reply #4 on: 10 March 2012, 07:45 »
If the solenoids are shot they might be constantly pulling the lock pins down.  When you pull the inner handle your fighting against them, then when you release they pull back down again.
I might be a camels ride away with my theory, but I've worked on plenty of vehicles in the past with this issue. (not golfs though)
Offline kennedyuk2001
« Reply #5 on: 10 March 2012, 11:53 »
I agree with bunj, sounds logical.
« Reply #6 on: 10 March 2012, 13:23 »
hmm worst thing is now my drivers door has decided it wont lock or unlock with central locking :/
Offline EsSeX dAn
« Reply #7 on: 10 March 2012, 13:33 »
just as a temporary fix get the door open, remove the doorcard and unplug the central locking. itll mean having to unloch via the doors but in my eyes a better bet than goin via the boot!
i think i love you.....
« Reply #8 on: 10 March 2012, 13:50 »
the locks are broke i think as car wont lock or unlock either side with key
Offline houston
« Reply #9 on: 10 March 2012, 17:11 »
remove the fuse for the central locking, then try the key, rules out the solenoid acting against you
