Author Topic: How do you wire things so they turn on and off with the ignition?  (Read 3215 times)
Offline jonrandom
Ive got a electronic boost controller and aquamist wired up to the battery but this would mean that they would stay on all the time even if the car is not running.
I was going to just put a 12v switch in the circucit so I could turn them off but is there any way to wire them so they switch on and off with the ignition?
Offline navmk4gti
Wire it to your headlight switch
Offline jonrandom
I dont know much about electrics so can you expand on that?
So does that mean they will turn on when I turn the lights on or ignition on and how do you wire them to the lights?
Offline navmk4gti
Im sure there ignitiOn wire on headlight swith.. Or u can wire up so only comes on when your lights are on.. This might help http://www.golfgtiforum.co.uk/index.php?topic=220652.0
Easy enough to sort, pull the light switch out and use a test lamp to find the switched live.
Offline jonrandom
Cheers lads should be able to sort this now  :smiley:
Offline 16valver dan
  • 1.8 20v turbo MK4 Golf
if not i wire stuff like that into ciggy lighter as thats an ignition based circuit
il update the sig when i get a good photoshoot ;)
I would be carefull with that, it does not like a lot of extra load.
true normally i just wire sumfin like a interior light in rear or summit to it
Offline Big Tone
Under the steering wheel, there are two terminals, one yellow, one red, one is switched live, one is permanent, dont know which Is which.
For a decent connection, wire into there.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
