Author Topic: How do you wire things so they turn on and off with the ignition?  (Read 3217 times)
Offline jonrandom
Under the steering wheel, there are two terminals, one yellow, one red, one is switched live, one is permanent, dont know which Is which.
For a decent connection, wire into there.
Ok nice one will have a look at the wkend if I can dig out a voltmeter.  :smiley:
Offline Big Tone
good stuff, plus you also have an earth terminal down there, what you wiring in?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline jonrandom
Its the aquamist water meth injection and the hks evc 6 electronic boost controller
Offline big stevie
  • "what doesnt kill me makes me stronger"
think you will find red is a perminent live and the yellow is switched, but check first with meter first though. :smiley: :smiley: :smiley:
black 5 door 18t aum engine with 19" lm reps and homemade induction, awesome forge 007p,pressed plates, pillar mounted boost and voltage gauge.
Offline jonrandom
Nice one mate you are a star  :smiley:
Offline tokemk4gti.t
  • 2001 gti turbo :-)
under your steering wheel theres a cushty little SW/L if u remove the cover o think its x75 or something close easy peasy thats easiest place.
Offline tshirt2k
  • Been there...Done that...
You dont just wire things in like that. That is asking for a fire to happen. Find a circuit that is large enough to take the load and make sure it is fused. Don't wire them to the same point either.
If you have to ask how to do this sort of thing, it probably not wise doing it.
Twisting and taping wires is asking for trouble. You should be crimping or even better, soldering and heat shrinking connections.
Mk3 ABF 16VT Megasquirt V3
Offline Big Tone
Like what? Headlight switch or terminals under steering wheel?
Other way?
Offline jonrandom
How else are you suppose to learn if you do not do things yourself? I understand it could cause a fire if you just wire it them in anywhere which is why im asking advice from anyone that has done this sort of thing before. I will be soldering and insulating all connections I just needed advice on where.
Offline tshirt2k
You learn by reading. You dont just tap into any old circuit, and you should always have a fuse holder in line for protection.
Learn to read vw current flow diagrams to find the right wires and circuits. If possible use a separate earth to prevent ground loops etc.
Modern Vw wiring is usually wrapped in loom tape and can be hard to trace wiring. That's where diagrams come in handy. If you need a specific diagram I have them.
