Author Topic: Top suspension mount adjustments??  (Read 1347 times)
Offline 1.6mk4GOLF16v
« on: 06 March 2012, 03:55 »
when i lift of the top suspension caps theres a bolt and a hexagonal adjustment inside the bolt therad (if that makes any sense) can some one explain this to me please before i go out and spend money on new suspension
would my suspension be the reason why i get a loud knocking noise when i turn left or right?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline Big Tone
Re: Top suspension mount adjustments??
« Reply #1 on: 06 March 2012, 06:57 »
Sounds like top mounts or wishbone bushes, or both!
That hex "stud" and nut is not for adjustment, it is to hold the strut in position when the weight is off the wheel, it should be tight.
Change the bushes and mounts before buying new suspension pal.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
« Reply #2 on: 06 March 2012, 07:45 »
i replaced the drop links, wishbones, and rubber top mounts last month, thats why i thought it might be the suspension,   :sad:
might jus get local kwick fit to look at it n work out what the problem is
any idea how tight i should make the hex stud?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline Big Tone
« Reply #3 on: 06 March 2012, 08:43 »
The hex is to put a 7mm allen key in and use it to hold against whist tightening the top cap down.
Don't know the torque figures off the top of my head but when you tighten down is is fairly slack then tightens up when in position, a hard stop.
Read the lowering spring/top mounts how to.
« Reply #4 on: 06 March 2012, 16:30 »
nice one for that  :smiley:
ok so ive just found out that the drive shafts on both sides are knackered and this is causing the knocking noise when turning or going over bumps
need to know the part number as theres a local scrappy near me whos got a few diff ones, did a search on here but didnt come up with anything  :sad:
is there a list somewhere? my cars a 51 plate AZD 1.6 16v
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline rio_gti
« Reply #5 on: 06 March 2012, 16:43 »
hahaha yeah cos they'll know...... bunch of retards!!!!
« Reply #6 on: 06 March 2012, 16:48 »
hahaha
well today i spent 1 hour in kwick fit and 2 hours in a back street garage and they both said its the drivers side drive shaft, kwick fit also spoted that i was leaking steering fluid !
anyone got access to EKTA to check a part numb for me?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
