Author Topic: very lumpy running when cold gti pirelli  (Read 4544 times)
Offline streetbeef
« on: 01 March 2012, 18:58 »
hey guys, im posting this on behalf of my mate who has a mk5 gti pirelli, when the engine is not up to temperate and accelerating under 2k revs its stuttering like its slightly mis-firing and has hardly any power, i experienced it the other day when he took me out in it and its definately not right!!  its not showing any fault codes whatsoever, when the car is up to 90 degrees it basically dissapears, any ideas???
2000 indigo blue golf gti AUM, full oe r32 kit, xenon headlights, r32 wheels, r32 interior trims,steering wheel,pedals and foot rest, h&r springs, r32 milltek cat-back, stage 1 remap, forge diverter valve.
Offline Saint Steve
Re: very lumpy running when cold gti pirelli
« Reply #1 on: 02 March 2012, 20:26 »
Spark plugs been replaced?
Offline streetbeef
« Reply #2 on: 03 March 2012, 07:32 »
Yes mate had 4 new plugs and coil packs yesterday and if anything he says its got worse! Could it be pcv?
Offline Saint Steve
« Reply #3 on: 04 March 2012, 18:33 »
Pcv would do it even when cold...
Have you checked the diverter valve? Diaphragm split..?
Offline streetbeef
« Reply #4 on: 04 March 2012, 18:50 »
I actually got to drive it yesterday and it seems very slow for a pirelli so I really think its the dv now!
Offline Hurdy
« Reply #5 on: 04 March 2012, 19:51 »
Also pull out the maf from the intake and check it isn't blocked or dirty. Can also give a lumpy idle when cold.
HPFP cam follower could be worn depending on mileage too. Doesn't usually give a poor performance though unless completely wrecked.
Seat Leon Cupra Black 290 DSG
Offline streetbeef
« Reply #6 on: 04 March 2012, 23:04 »
Thanks for the help, will keep you updated on how's its going, dv and pcv he is replacing tomorrow  :smiley:
Offline streetbeef
« Reply #7 on: 18 March 2012, 13:25 »
just an update, well my mate has replaced the dv, all 4 coil packs and plugs, and the pcv with the latest revision and it still does it!  its driving him mad, is mis-fires quite badly on cold start and just gives a slight mis fire under light throttle and feel as if its holding back, but when it gets to 90 degrees it seems to be ok and still no fault codes?!  very confusing  :huh:
Offline bacillus
« Reply #8 on: 18 March 2012, 15:17 »
Is this car remapped?
Without traction power is nothing!
Offline streetbeef
« Reply #9 on: 19 March 2012, 08:28 »
No its standard and has 60k on it
