Author Topic: very lumpy running when cold gti pirelli  (Read 4563 times)
Offline pandahouse68
Re: very lumpy running when cold gti pirelli
« Reply #10 on: 19 March 2012, 19:01 »
just an update, well my mate has replaced the dv, all 4 coil packs and plugs, and the pcv with the latest revision and it still does it!  its driving him mad, is mis-fires quite badly on cold start and just gives a slight mis fire under light throttle and feel as if its holding back, but when it gets to 90 degrees it seems to be ok and still no fault codes?!  very confusing  :huh:
could be coolant temp sensor G62
Offline streetbeef
« Reply #11 on: 20 March 2012, 07:35 »
That would make sense mate, I will tell him today take it from there thanks, are they quite common on Mk5's then?
2000 indigo blue golf gti AUM, full oe r32 kit, xenon headlights, r32 wheels, r32 interior trims,steering wheel,pedals and foot rest, h&r springs, r32 milltek cat-back, stage 1 remap, forge diverter valve.
Offline streetbeef
« Reply #12 on: 21 March 2012, 11:33 »
Just found out the plugs he put in the other week are far too cold running for the car are the oem plugs for the pirelli the ones to go for?
