Author Topic: Brake q  (Read 6364 times)
Offline navmk4gti
Brake q
« on: 25 February 2012, 01:53 »
Been doing some reading up as im getting a wobble when i brake sharply.. How do i check the discs are warped? The discs are only year old but thought check them too.. Will be changing tracking rods and pads next week.. Had look at pads they dont actualy look that bad :undecided:
Also at high speed 90mph plus ( private road ofcourse :evil:) the steering shakes quite bad .. Iv had wheelS balanced and even got new tyres all around.. Would a knackered steering rack cause this or a warp disc  :undecided:
Offline rockmonkey69
Re: Brake q
« Reply #1 on: 25 February 2012, 02:03 »
Play in steering rack or a warped disc both give the symptoms you describe, take your disc off and have it checked. Majority of cars I service, it's those using eBay grooved or drilled discs that warp.
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Brake q
« Reply #2 on: 25 February 2012, 02:42 »
Would this also be the same as an advisory on your MOT for 'brake imbalance' ? I got this advisory a month or so ago and they mechanic said the brakes probably just need a good clean out...
Offline golfyste
  • Project track car
Re: Brake q
« Reply #3 on: 25 February 2012, 07:06 »
A good way of checking the brakes is to get a magnetic DTI and put on te wing and put the tip on the disc and the. Turn it and look out for the differential in measurement.
Offline johnomk4
Re: Brake q
« Reply #4 on: 25 February 2012, 07:31 »
+1. That's if you have one tho.
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: Brake q
« Reply #5 on: 25 February 2012, 09:10 »
+2 thats if you have a dti or even know what one is.have them at work not cheap to buy a decent one though.also if you do this put somethnig under the magnet as might scrath paint taking it off.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline RnP
  • Audi S4 gone, looking for b5 rs4
Re: Brake q
« Reply #6 on: 25 February 2012, 10:46 »
wobble at high speed sounds like track rod end
Offline golfyste
  • Project track car
Re: Brake q
« Reply #7 on: 25 February 2012, 12:48 »
Yeah forgot to mention that haha I would never do it and wouldn't reccomeded it either  :laugh:
Offline navmk4gti
Re: Brake q
« Reply #8 on: 25 February 2012, 13:51 »
Whats a dti thingy bob thing :lipsrsealed: :grin:
Yh im goin to change track rod end as one them is completly covered in rust and
Will change pads as been over a year since changed them.. Hopefuly that will sort it dont wana replace discs again
Offline golfyste
  • Project track car
Re: Brake q
« Reply #9 on: 25 February 2012, 14:05 »
DTI stands for "dial test Indictator" it is basically a dial on a rod with a magnetic base and it has a pointer that can move in and out and as it does the dial reads how far it has moved normally in thousandths of a inch and to .01mm etc
So you put it on your wing and put the pointer on your disc and rotate the outside of the dial so the poi ter is pointing to 0 and then spin your disc and watch move any movement on the dial.
They also used for measure the concentric it's of shafts in motors, turbos etc
 :smiley:
« Last Edit: 25 February 2012, 14:07 by golfyste »
