Author Topic: Brake q  (Read 6365 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: Brake q
« Reply #10 on: 25 February 2012, 14:49 »
Whats a dti thingy bob thing :lipsrsealed: :grin:
Yh im goin to change track rod end as one them is completly covered in rust and
Will change pads as been over a year since changed them.. Hopefuly that will sort it dont wana replace discs again
DTI stands for "dial test Indictator" it is basically a dial on a rod with a magnetic base and it has a pointer that can move in and out and as it does the dial reads how far it has moved normally in thousandths of a inch and to .01mm etc
So you put it on your wing and put the pointer on your disc and rotate the outside of the dial so the poi ter is pointing to 0 and then spin your disc and watch move any movement on the dial.
They also used for measure the concentric it's of shafts in motors, turbos etc
 :smiley:
+1 you in enginering by any chance mate?
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline navmk4gti
Re: Brake q
« Reply #11 on: 25 February 2012, 14:59 »
Thats some techy stuff.. Wb just spining the disc and puting hand on it and feel if there uneven groove :grin:
had quick feel discs today they arent that worn in at all so think they all
Good.
any idea hw much dealer charge brake pads all places near me give crappy jap copys which dont last at all :undecided:
Offline golfyste
  • Project track car
Re: Brake q
« Reply #12 on: 25 February 2012, 15:26 »
 :smiley:
Yeah mate only 18 tho just comin to the end of my apprenticeship  :smiley:
Good.
You can't normally feel it as the "weave" could occurs over half a turn o the disc so unless you hole the Wing incredibly tight and have solid finger you won't be able to feel it  :laugh:
Dunno about dealer but have a look on places such as awesome, larkspeed and venom for performance pads dunno about own, tps maybe?
Offline navmk4gti
Re: Brake q
« Reply #13 on: 25 February 2012, 16:01 »
awesome are getting close to being as crazy as stealers now .. will give tps a ring on monday then.. the front are 256mm and rear are 212mm is that right on a AGU?  :smiley:
Offline golfyste
  • Project track car
Re: Brake q
« Reply #14 on: 25 February 2012, 16:12 »
Ok mate, yeah bits like that don't tend to be cheap from then but they are good or bits like ricirc valve etc
You mean disc size?
Are they not 288 front and 232 on the rear?
Offline navmk4gti
Re: Brake q
« Reply #15 on: 25 February 2012, 16:26 »
sorry my bad it is 288 front 256 rear  :grin:
ill try sourcing some mintex never tried them before  :smiley:
Offline golfyste
  • Project track car
Re: Brake q
« Reply #16 on: 25 February 2012, 16:31 »
 :grin: ok mate you got the rear 256 upgrade I'm guessin then.
I heard Mintex are ok and normally quite cheap never tries them myself tho.
Ok mate good luck with the search  :cool:
Offline navmk4gti
Re: Brake q
« Reply #17 on: 25 February 2012, 16:39 »
no not got upgrade... there 232 actualy just checked on some brakes site :laugh: got there in the end  :grin:
Offline golfyste
  • Project track car
Re: Brake q
« Reply #18 on: 25 February 2012, 16:45 »
Haha thought so   :laugh:
Can't wait to get my 288's on the rear .....looks a bit daft with 340's on the front and 232's on the back haha  :grin:
Offline navmk4gti
Re: Brake q
« Reply #19 on: 25 February 2012, 16:49 »
if my discs are warped i will just for upgrade then 312's and 256 rears  :evil:.. found few brake pads will post links when get home at work at the mo  :lipsrsealed:  :grin:
