Author Topic: What's this connector?  (Read 3595 times)
Offline murraymint
« on: 22 February 2012, 19:18 »
Saw this connector/plug thing at the back of my engine bay, and was wondering what it is/ does?
It's the one to the left of the horn. Can't see anything it should be connected to? (haven't looked very hard tho as it was raining)
« Last Edit: 22 February 2012, 21:30 by murraymint »
josh
Offline Screech16v
  • MK3 20vt AGU
Re: What's this connector?
« Reply #1 on: 22 February 2012, 19:30 »
Looks like ABS control mod plug.
Offline murraymint
« Reply #2 on: 22 February 2012, 19:31 »
O right  :undecided:. What's that mean if it is and it's not connected?
josh
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 22 February 2012, 19:37 »
That means no ABS FOR YOU! is the usual brake distrubution block and pump still there or has it been converted to non ABS or something :undecided:
Offline murraymint
« Reply #4 on: 22 February 2012, 19:40 »
I don't know. Il have to have a look. Btw what and where am I looking/for? Never had to deal with abs before
josh
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #5 on: 22 February 2012, 19:42 »
Does it have all this.....
Offline Deano2711
  • 1992 VR6
« Reply #6 on: 22 February 2012, 19:52 »
Could it not be for an after market alarm ??  If it was ABS surely the light would be on dash.
Offline murraymint
« Reply #7 on: 22 February 2012, 19:53 »
Just looked and No  :undecided:. So first thing figured out I have no ABS  :sad:, but theres a bracket been made up and the brake line have been redirected, (so not a total bodge job which is good.
Next question, on the back of that plug in the pic I posted. Has a black wire and a white that has been cut, and two new wires have been soldered in and they go back into the car. I'm gunna have a proper look at the weekend were the wires go but for now any ideas what these are doing?
josh
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 22 February 2012, 19:56 »
Does the light come on with ignition then go off after the self check? defo  been messed with and needs to be sorted
Offline murraymint
Re: What's this connector? Edit no ABS :(, new question
« Reply #9 on: 22 February 2012, 19:58 »
Yh I know gunna have a proper look at I this weekend and gunna sort it ASAP! No the light doesn't do anything, but the airbag one is normal, so thort this was normal when I bort it as my old 1.6 didn't have abs so didn't know what to expect
josh
