Author Topic: What's this connector?  (Read 3597 times)
Offline Screech16v
  • MK3 20vt AGU
Re: What's this connector? Edit: no ABS :(, new question
« Reply #10 on: 22 February 2012, 20:02 »
Thought that would be the case :rolleyes: ,previous owner probably had issues and ripped it all out :rolleyes: :rolleyes:loks like you got some parts to buy,lets hope all the wheel sensors are still there,be careful mate because you will have no brake bias as it is controlled through the abs system.
Offline murraymint
« Reply #11 on: 22 February 2012, 20:09 »
Great  :angry:. Well at least I know what needs sorting now tho, cheers guys. So question number 3. What parts needed? Already had a quick look on eBay and abs pumps are fairly cheap which is good. Il have a look for sensors are ther but may aswell replace them too. so so far the list is
Abs pump
O/s, n/s sensors
Please can you completebthe list for me?
Thanks for the help guys!
josh
Offline Screech16v
  • MK3 20vt AGU
Re: What's this connector? Edit: no ABS :(,another new question
« Reply #12 on: 22 February 2012, 20:15 »
Abs pump
O/s, n/s sensors
Control module(ECU)
Distrubution block
ABS light cluster
EDIT.
The ecu will have to come from another 16v or vr only as they have the brake bias control and edl,then i think it will need to be recoded to your car somehow,some one correct me if they know better. :smiley:
« Last Edit: 22 February 2012, 20:21 by Screech16v »
Offline murraymint
« Reply #13 on: 22 February 2012, 20:17 »
Is that everything? Off to eBay for me.
josh
Offline murraymint
josh
Offline Screech16v
  • MK3 20vt AGU
« Reply #15 on: 22 February 2012, 20:46 »
http://www.ebay.co.uk/itm/1H2-614-117-B-VW-VOLKSWAGEN-GOLF-MK3-GTI-BRAKE-ABS-PUMP-/270289260574?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3eee7ed01e#ht_1479wt_689
Is this the pump and the distribution block or just the pump?
Thats the pump ,block and ecu but you need a 16v set up which has differences as in brake bias control,look for people breaking 16v and vr6 of similar age to yours.
Offline murraymint
« Reply #16 on: 22 February 2012, 20:50 »
That's got all three? Would be ideal. Yh I've pm'd a couple people breaking 16v's. Is it true what you said about needing to get it recoded? If so how would I got about doing this?
josh
Offline Adezmk3
« Reply #17 on: 22 February 2012, 21:01 »
What year is yours mate? You can have the ABS stuff off our car for fairly cheap but you wana be sure its the right bits. You do realise your going to need to make all new brake lines etc as well? Also how do you know your ECU isn't still set up for an ABS system? It could just work from plugging it all back in again.
Offline murraymint
« Reply #18 on: 22 February 2012, 21:04 »
It's an N reg 95. That would be ideal bud. My dads mates a mechanic and has his own garage so reckon I'm gunna get him to have a look/ do it for me.
josh
Offline Adezmk3
« Reply #19 on: 22 February 2012, 21:09 »
Ours is a 97 ABF, see if you can get the dealers to give you the part number for the abs module you should have fitted and we can see if its the same as the module on ours. They may have changed it
