Author Topic: What's this connector?  (Read 3598 times)
Offline Screech16v
  • MK3 20vt AGU
Re: What's this connector? Edit: no ABS :(,another new question
« Reply #20 on: 22 February 2012, 21:10 »
That's got all three? Would be ideal. Yh I've pm'd a couple people breaking 16v's. Is it true what you said about needing to get it recoded? If so how would I got about doing this?
Not to sure about the coded bit,but when i changed my ABS ECU for another that had the same serial number with a different letter at the end it didnt work so i scanned it and it said incorrectly coded or something like that  :undecided: im sure it can be sorted though with the correct equipment.
Offline murraymint
« Reply #21 on: 22 February 2012, 21:11 »
Okay I will do cheers.
Thanks for the help guys!!!  :smiley:
josh
Offline boneybradley
  • Back in a Mk3...
« Reply #22 on: 23 February 2012, 12:14 »
Just rememeber there 2 types of abs fitted to the 1995 models. early cars have the abs ecu uner the rear seat (and a brake bias valve)
and later the ecu is with the abs pump (and as said before dosent have a bias valve)
