Author Topic: mk4 Gamma CD stuck!  (Read 6775 times)
Offline Mr_Orange
mk4 Gamma CD stuck!
« on: 14 February 2012, 18:58 »
I've just whipped out the factory fit Gamma CD and radio units, replaced with a nice Kenwood DPX503u.  Problem is, where did my favourite CD go?
Went looking and I've foolishly left it inside the Gamma CD deck!  I've taken the covers off the player and the CD is physically retained.  There's a pair of metal plates popped up after it was inserted.  Is there any way to manually eject a disc with these?  Must be something can be pressed to open the mechanism.
Here is the unit with the front trim removed.  See the two metal plates in CD slot:
I really cannot bear the thought of stripping the Kenwood out to access the power supply.
« Last Edit: 16 February 2012, 19:32 by Mr_Orange »
Build thread clicky
Offline dragonfly
Re: mk4 Gamma CD stuck!
« Reply #1 on: 16 February 2012, 19:25 »
Give it 12 volts and eject the cd.
Offline Mr_Orange
« Reply #2 on: 16 February 2012, 19:27 »
Where can I get a power source?
Build thread clicky
Offline dragonfly
« Reply #3 on: 16 February 2012, 19:31 »
Car battery - most systems will automatically eject a cd when give it power after it's been disconnected.
Offline Mr_Orange
« Reply #4 on: 18 February 2012, 19:19 »
Got a 12V DC power supply from an old scanner and cut the plug off the end.  A couple of paper clips later, fingers crossed and hey-presto the CD popped straight out.  Thanks mate  :grin:
« Last Edit: 18 May 2012, 07:04 by Mr_Orange »
Build thread clicky
Offline stuartb3502
« Reply #5 on: 18 March 2012, 19:31 »
This has made me think.  I have a handful of CDs missing and a Gamma CD stuck out in a box in the garage - must give it some juice and see if it gives up anything  :smiley:
« Last Edit: 18 March 2012, 19:44 by stuartb3502 »
2010 GTD.  RNS510 and Bluetooth fitted.  Hertz Hsk165xls, Audison Bt ten D, Hertz Hdp 4, Rockford Fosgate mono amp. Hertz 12" sub.  VCDS HEX+CAN available Camberley
Golf TDi 130 (Alpine head unit/iPod with Alpine KTP445 in-dash amp. behind glovebox).  Mission components front, OEM rears.  Kenwood 10" sub and Rockford Fosgate amp in removable box in the boot.
Offline Mr_Orange
« Reply #6 on: 18 March 2012, 19:39 »
This has made me think.  I have a handful of CDs missing and a Gamma CD stuck out in a box in the garage - must give some juice and see if gives up anything  :smiley:
Give it some 12V and it will spit it straight out!
Build thread clicky
Offline stuartb3502
« Reply #7 on: 16 May 2012, 20:32 »
Only just getting round to this.  Does anyone happen to have a pinout?  I presume its the 2 pin connector, but don't nw which round.  Could not find a diagram when i Googled.  Thanks
Offline Mr_Orange
« Reply #8 on: 16 May 2012, 21:28 »
Yo!  Have a look about 1/4 the way down on this legendary link:
http://uk-mkivs.net/forums/t/177496.aspx?PageIndex=1
Build thread clicky
Offline monty9120
« Reply #9 on: 17 May 2012, 09:35 »
if you have a jump pack you can use that too
