Author Topic: mk4 Gamma CD stuck!  (Read 6770 times)
Offline stuartb3502
Re: mk4 Gamma CD stuck!
« Reply #10 on: 17 May 2012, 20:31 »
Cool thanks, so its actually on the multi pin plug.  I had thought it was the 2 pin one.  Will give it a whirl thanks.  I'd not seen that thread before; good stuff.
S.
2010 GTD.  RNS510 and Bluetooth fitted.  Hertz Hsk165xls, Audison Bt ten D, Hertz Hdp 4, Rockford Fosgate mono amp. Hertz 12" sub.  VCDS HEX+CAN available Camberley
Golf TDi 130 (Alpine head unit/iPod with Alpine KTP445 in-dash amp. behind glovebox).  Mission components front, OEM rears.  Kenwood 10" sub and Rockford Fosgate amp in removable box in the boot.
Offline stuartb3502
« Reply #11 on: 19 May 2012, 15:41 »
Not having any luck.  I have plugged in an ISO adapter and applied 12V+ to permanent live no 1 (pin 7 red) grounded to pin 8.  I get the red flashing security light on the TIM button.  If I then apply 12V+ also to ignition switched live (pin 4 yellow), the red flashing light goes out but nothing else happens.  I notice in that diagram that there is a permanent live 2 (pin 5 blue) - that would normally be a power out rather than in on an ISO lead so I haven't applied 12V to that.
Any more clues?
Thanks
Stuart
« Last Edit: 19 May 2012, 16:02 by stuartb3502 »
Offline stuartb3502
« Reply #12 on: 19 May 2012, 17:59 »
OK - you do need to connect power to both permanent lives.  That worked.  No CD, but at least I know the new owner will be getting a working unit.
Thanks all.
