Author Topic: Heater problems after head gasket change. HELP!!!  (Read 1812 times)
Offline greenhornetgti
« on: 11 February 2012, 18:56 »
Hi ive just changed the the head gasket on my 1.6 golf e/c AEH but the heaters are blowing cold, i have tried bleeding but it makes no difference. has anyone got any ideas or know if theres a specific way to bleed them? Any help is much appreciated.
Offline jonnyturbo
Re: Heater problems after head gasket change. HELP!!!
« Reply #1 on: 11 February 2012, 18:57 »
themostat ?
« Reply #2 on: 11 February 2012, 19:09 »
cheers i thought i might be that, i'll change it and see what happens. do you know if you have top bleed them in a specific way?
Offline jonnyturbo
« Reply #3 on: 11 February 2012, 19:32 »
Could well be temp sender also
« Reply #4 on: 12 February 2012, 10:33 »
just changed the thermostat and its still blowing cold air. any other ideas. does it need jacked up and bleed or something?
Offline badboybunty
« Reply #5 on: 12 February 2012, 10:53 »
flush coolent system if coolent/oil mixed :smiley:
Offline badboybunty
« Reply #6 on: 12 February 2012, 10:55 »
also put heaters on full blast on windscreen might have a airlock
« Reply #7 on: 12 February 2012, 11:00 »
cheers mate i'll give it a go now and let you know how i get on
« Reply #8 on: 12 February 2012, 12:02 »
i've tried all the above but still no joy, i also flushed the heater matrix and refilled the water system but when i feel the matrix pipes one is hot and the other is cold. is there anyway i can force the air locks?
Offline badboybunty
« Reply #9 on: 12 February 2012, 12:48 »
did oil/water mix in the expansion bottle sounds like blockage or air lock
