Author Topic: Heater problems after head gasket change. HELP!!!  (Read 1810 times)
Offline badboybunty
Re: Heater problems after head gasket change. HELP!!!
« Reply #10 on: 12 February 2012, 12:57 »
if no joy at end of day take for a spin with heaters full blast park up take cap off slowly and leave to cool over night trapped air will escapeas cools down :wink:
Offline greenhornetgti
« Reply #11 on: 12 February 2012, 13:36 »
yeah the oil got into the water. how do i get a blockage out, do i flush it with a hose pipe?
Offline badboybunty
« Reply #12 on: 12 February 2012, 13:44 »
taken from another site while searching but never done this before:
Simply mix a solution of 50% bleach and 50% water. Drain the vehicles cooling system and then refill with the new mixture. Run engine until at normal operating temp and then switch off. When engine has cooled sufficiently, drain and refill with the correct antifreeze/ water mixture. The cooling system of your engine will have been thoroughly cleaned by this method (as recommended by Vauxhall).
http://www.honestjohn.co.uk/forum/post/index.htm?t=51700
« Last Edit: 12 February 2012, 13:46 by badboybunty »
« Reply #14 on: 12 February 2012, 14:46 »
cheers i'll give it a go next, thanks for all your help mate
Offline badboybunty
« Reply #15 on: 12 February 2012, 15:07 »
no worries mate keep us informed how you get on :wink:
