Author Topic: Front hub nut stuck fast!  (Read 3662 times)
Offline AudiA8Quattro
Re: Front hub nut stuck fast!
« Reply #10 on: 09 February 2012, 00:18 »
ahh thanks twotwofour but thats a little far lol  the axle stand idea looks ok i guess,a little dodgy but hey!
Why is it dodgy?
The car is secure on the floor, the bar is supported, so what can go wrong?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 09 February 2012, 00:42 »
Broken body.  :lipsrsealed:
Offline twotwofour
« Reply #12 on: 09 February 2012, 09:21 »
And wing/alloy if something slips.
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline Diamond Hell
  • Opinions я Us
« Reply #13 on: 09 February 2012, 13:15 »
The idea of the axle stand is that nothing will slip, because everything is supported and square.  :rolleyes:
Don't use a torque wrench to undo it - the torque wrench is designed as a measuring device not a brute force administration device.  Get a strong-arm bar instead.
Offline dub-gti
« Reply #14 on: 09 February 2012, 15:46 »
yes, use a longer bar, or a pole on the ratchet, at least a meter long,
other way is to drive it off. done this once before.
have the bar lent to the florr and slowly drive forward to make the ratchet undo the nut.
Depends which side its on ,will have to reverse if on the N/S ,should come off the normal way though with car on the ground and enough leverage.
never siad forward or backwards, knowing which way to drive it would be simple enough,
just use a bar, easiest way. and if your going to use a extension bar for no reason then use the axle stand
« Reply #15 on: 09 February 2012, 17:55 »
Exactly.
Anyone that has done it this way knows that it's the safest way and it won't slip.
In the pic i have used a large 3/4 inch drive breaker bar, these do not flex like the 1/2 inch drive ones.
Offline Screech16v
  • MK3 20vt AGU
« Reply #16 on: 09 February 2012, 20:42 »
Yes you did   :rolleyes:
Offline dub-gti
« Reply #17 on: 09 February 2012, 22:35 »
lol oops so i did  :laugh: :cry:
any how get a mile long bar and your be good!  :tongue:
Offline Screech16v
  • MK3 20vt AGU
« Reply #18 on: 10 February 2012, 17:59 »
:laugh: :wink: :smiley:
