Author Topic: Front hub nut stuck fast!  (Read 3652 times)
Offline EsSeX dAn
« on: 08 February 2012, 18:46 »
its on a mk3 vr6 front hub,i cant persuade the nut to come undone! ive heated it,wd40'd it leant on it with a torque wrench the lot. it refuses to budge.tomorrow ill be bolting the wheel back on lowering car down,in gear and handbrake on and lean! any other ideas?
i think i love you.....
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Front hub nut stuck fast!
« Reply #1 on: 08 February 2012, 19:16 »
They are very very tight fitted from factory (265Nm) and loctited in place so will you need a 3/4" breaker bar at least with probably a long bar over that. Best bet is to do it on the ground with wheel on as if its up on a axle stand the force needed will more than likely topple it.
Offline dub-gti
« Reply #2 on: 08 February 2012, 19:16 »
yes, use a longer bar, or a pole on the ratchet, at least a meter long,
other way is to drive it off. done this once before.
have the bar lent to the florr and slowly drive forward to make the ratchet undo the nut.
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 08 February 2012, 19:32 »
Depends which side its on ,will have to reverse if on the N/S ,should come off the normal way though with car on the ground and enough leverage.
Offline EsSeX dAn
« Reply #4 on: 08 February 2012, 20:34 »
its drivers side soo it should be a standard thread? im off out to find a long bit of hard tube then!
Offline twotwofour
« Reply #5 on: 08 February 2012, 21:56 »
I think your in essex?
I have an inch drive impact gun that would make easy work of that but im in west yorks
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline AudiA8Quattro
« Reply #6 on: 08 February 2012, 21:58 »
ALWAYS undo the hub nut when the car is on the ground.
« Reply #7 on: 08 February 2012, 22:00 »
If you don't have an impact gun, use a big breaker bar and an axle stand, then stand on the breaker bar.
A 3/4 inch breaker bar is better.
Like this..
Offline Khare
  • The bear that khares
« Reply #8 on: 08 February 2012, 22:23 »
Like this..
That's the best way, remember the axle stand!
Offline EsSeX dAn
« Reply #9 on: 08 February 2012, 22:39 »
ahh thanks twotwofour but thats a little far lol  the axle stand idea looks ok i guess,a little dodgy but hey!
