Author Topic: timing dizzy wont move far enough!  (Read 4715 times)
Offline Simpson
  • one day il learn
« on: 06 February 2012, 20:42 »
I did the cambelt a few weeks ago on my 8v mk2 digi, i marked all the belts and refitted new belt. All seemed fine at the time but now the car has been pinking for a few weeks finally twigged why doh!
nyway i got my timing light out and its way off managed to get it a little better but i cant find thetdc mark as the dizzy hits the block as far as i can turn it, my only explanation is i have knocked it a tooth out leading to the dizzy being in the wrong place? any help would be appreciated,
I take it i should redo engine timing again or can i change rotor arm 180 degress? thanks in advance
i must buy a new car!
Re: timing dizzy wont move far enough!
« Reply #1 on: 06 February 2012, 20:44 »
Better to redo the timing.
Offline molegti
« Reply #2 on: 06 February 2012, 20:45 »
Id check the valve timing first
Offline Simpson
  • one day il learn
« Reply #3 on: 06 February 2012, 21:09 »
will do hope it aint done any damage :smiley: i always struggle to get it exaclty right as when there is tension on the belt the tooth moves is is half a tooth out!
Offline danny_p
« Reply #4 on: 06 February 2012, 22:54 »
you can move the plug leads round 1 position    to bodge and scarper it
all the VW's have gone bar 1.
Offline Simpson
  • one day il learn
« Reply #5 on: 07 February 2012, 09:54 »
nice thought but that might get confusing, that is asssuming they are in the right order already, so will my dizzy be 180 out on the oil pump? or i guess it wouldnt run at all then! il recheck timing and then do dizzy timing again, thnks again
Offline Sam
  • Sam I am
« Reply #6 on: 07 February 2012, 10:47 »
It wouldnt run at all I dont think. Just undo it all and re-fit belt. Not a big job and saves bodging it  :smiley:
Offline Simpson
  • one day il learn
« Reply #7 on: 07 February 2012, 23:10 »
so took it to the garage today as havent got the time to sort it right now, bloody charged me 60 quid to f**k it up, they left the idle too high and the belt too tight and once i had adjusted it, it started to cut out and buck and jump when cold, they said the intermediate shaft was about 5 or 6 teeth out, so it must be close i am not sure why its running lumpy it was better before, dont you sometimes think you wish you had done it yourself!
i am going to check with my timing gun in the morning, cheers
Offline Sam
  • Sam I am
« Reply #8 on: 07 February 2012, 23:33 »
How come you paid if it runs like a bag of sh!t?
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« Reply #9 on: 08 February 2012, 21:08 »
There is a mark on the intermediate shaft.
