Author Topic: Where the hell is my coolant temp sensor?  (Read 2239 times)
Offline stainesy
« on: 26 January 2012, 17:46 »
As it tittle where the hell is my temp sensor? I can't find it anywhere.
It's the 1.6 16v engine.
It's doing my head in now.
Does anybody tell me where it's located PLEASE
« Last Edit: 26 January 2012, 18:07 by stainesy »
Offline Chris#101
Re: Where the hell is my temp sensor?
« Reply #1 on: 26 January 2012, 17:49 »
it should be located near the grill being your front bumper I think
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline stainesy
« Reply #2 on: 26 January 2012, 18:07 »
Sorry my bad ment the coolant temp sensor.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Where the hell is my coolant temp sensor?
« Reply #3 on: 26 January 2012, 18:08 »
right hand side of the engine, you will see a plug going to a pipe, it's under there
Offline stainesy
« Reply #4 on: 26 January 2012, 18:52 »
iv been looking most of the day just cant find it. had them pipes off today.
where is it near the thermostat?
anybody got a pic of it on the 1.6 16v?
Offline daz veedub
  • Operation 1.8t bolf
« Reply #5 on: 26 January 2012, 18:58 »
its the green plug u can just see the green onit make sure ur car isnt warm/hot when u remove as water will piss out
remove retaining clip but keep it incase another didnt come with the new sensor then the plug will pull out
Offline Deano2711
  • 1992 VR6
« Reply #6 on: 26 January 2012, 19:10 »
Good advice as it bloody hurts when hot  :grin: :grin:
Offline stainesy
« Reply #7 on: 26 January 2012, 19:25 »
cheers mate. what engine is that on? look completely diferant to mine.
Offline daz veedub
« Reply #8 on: 26 January 2012, 19:31 »
a just googled bora engine images
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 26 January 2012, 19:38 »
comes off the thermostat housing on a 1.6 if i remember right. should be plainly visible to be honest, especially if you have the new sensor in your hand to compare.
