Author Topic: Where the hell is my coolant temp sensor?  (Read 2240 times)
Offline xtetx
Re: Where the hell is my coolant temp sensor?
« Reply #10 on: 26 January 2012, 20:10 »
ive got a 1.6 16v golf, im sure its the same engine, take off the top cover, its on the right hand side, mine was green and it has a c clip keeping it on. If you want me to take a pic let me know and i will take the cover off and show you.
Offline stainesy
« Reply #11 on: 26 January 2012, 20:14 »
ok nice1 i will have a look there tomorrow and if i cant find it i will post a pic up on mine aswell.
Offline xtetx
« Reply #12 on: 26 January 2012, 20:14 »
sweet dude, u got rid of the mk3 now?
Offline stainesy
« Reply #13 on: 26 January 2012, 20:22 »
yeah swapped it for the bora in my sig pic. everything is sweet on it apart from this bloody heater issue.
Offline xtetx
« Reply #14 on: 26 January 2012, 20:25 »
nice swap man, yeah mine went recently. stopped my car from starting after short journeys! did my head in, cost bout £35 from vw and a 5 min fix :)
Offline stainesy
« Reply #15 on: 26 January 2012, 20:32 »
im not having any trouble with mine like that. my temp stays at 90 spot on all the time. but have tried everything els to get my heater to blow hot air and thats the only thing ni havnt tried.
Offline xtetx
« Reply #16 on: 26 January 2012, 20:36 »
nightmare man, good luck with the fix!
Offline mattkh
« Reply #17 on: 26 January 2012, 20:51 »
Hi
The temperature sensor wont have anything to do with it, I feel. What exactly is the heater issue ?
Offline topher
  • Administrator
  • fully functioning
« Reply #18 on: 26 January 2012, 20:57 »
as above, temp sensor has no effect on the heaters
if the water going in to the matrix is hot, most probable cause is a knackered flap motor on the blower housing behind the dash. vagcom will reveal more..
Offline stainesy
« Reply #19 on: 26 January 2012, 22:20 »
it has a flap motor?
on mine when i turn the heat dial i can feel and hear a diferance in blower power and i can hear the flap flap over. also it get a tiny bit warmer than cold when i put the heater on. is it not a cable as it feels like its cable operated.
