Author Topic: Where the hell is my coolant temp sensor?  (Read 2242 times)
Offline topher
  • Administrator
  • fully functioning
Re: Where the hell is my coolant temp sensor?
« Reply #20 on: 26 January 2012, 22:42 »
if its manual heaters it will be cable operated yeah sorry, i get stuck in a GTI mindset :grin:
could be a blocked matrix then?
Offline stainesy
« Reply #21 on: 26 January 2012, 22:54 »
it cant be i had both pipes of earlyer and and blow water through it and water flow was fine.
Offline topher
  • Administrator
  • fully functioning
« Reply #22 on: 26 January 2012, 23:01 »
that wont really test it, you need to check the temperature difference between the inlet and outlet hoses
edit: and sometimes that won't even work, if the core is full of gunk and the pressure has burst through the dividing wall in the end tank :undecided:
« Last Edit: 26 January 2012, 23:04 by topher »
Offline stainesy
« Reply #23 on: 26 January 2012, 23:34 »
ah right didnt realise it could do that. how much is it to get a heater matrix changed these days? never had to do one before.
Offline topher
  • Administrator
  • fully functioning
« Reply #24 on: 26 January 2012, 23:46 »
isn't cheap, whole dash needs to come out. It's not so bad as a DIY job though it just takes a long time
