Author Topic: removing strut  (Read 3724 times)
Offline mcgee9t2
removing strut
« on: 21 January 2012, 16:51 »
is this just because i dont have a spreader tool that i cant remove my strut from  the strut mount?
surely if theres this much play the strut should be able to come off...
http://www.youtube.com/watch?v=9edeY07jrpw&feature=youtu.be
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: removing strut
« Reply #1 on: 21 January 2012, 17:22 »
drivers side?
Offline mcgee9t2
Re: removing strut
« Reply #2 on: 21 January 2012, 17:25 »
that was yes
Offline Chris.
Re: removing strut
« Reply #3 on: 21 January 2012, 17:27 »
Get a nice big bar, wedge it under the shaft and above wishbone, secure one end under the chassis and get someone to stand on it.
Click For Build Thread
Offline dilbert
Re: removing strut
« Reply #4 on: 21 January 2012, 17:28 »
You have to leave the top mount tight. Lever down the lower arm whilst knocking the hub down the suspension leg.
Use a copper hammer so it doesn't damage the hub
mk4 golf 1.8 gti 20v
Offline mcgee9t2
Re: removing strut
« Reply #5 on: 21 January 2012, 17:29 »
tried, at one point i even had a jack pushing down on top of it and still no movement  :shocked:
Offline mcgee9t2
Re: removing strut
« Reply #6 on: 21 January 2012, 17:30 »
that is with the topmount tight  :lipsrsealed:  and was using a big copper hammer/mallet type thing, still cant get it any further down  :undecided:
Offline Chris.
Re: removing strut
« Reply #7 on: 21 January 2012, 17:30 »
ARB drop link undone?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: removing strut
« Reply #8 on: 21 January 2012, 17:34 »
drivers side is harder as it doesn't drop as far
Offline Chris.
Re: removing strut
« Reply #9 on: 21 January 2012, 17:35 »
Id undo the shaft and ler it slide out to allow the hub to slide right down.....nothing stopping it then.
