Author Topic: removing strut  (Read 3755 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: removing strut
« Reply #30 on: 27 January 2012, 14:08 »
One thing you could try is cable tie the spring when it's compressed (I take no responsibility for any accidents)
use loads of thick cable ties if you have them
Offline mcgee9t2
Re: removing strut
« Reply #31 on: 27 January 2012, 14:09 »
thats one thing i was thinking, though dont have any thick ones, only thin ones :/ and nowere around here sells thick cable ties or anything remotly like that  :sad:
hmm wonder if i have any chains in the shed :D
Offline dilbert
Re: removing strut
« Reply #32 on: 27 January 2012, 20:16 »
put it back together and take it to a reputable garage mate
mk4 golf 1.8 gti 20v
Offline Chris.
Re: removing strut
« Reply #33 on: 27 January 2012, 21:52 »
Try moving the clamps closer together?
Click For Build Thread
Offline RhosneigrGaz
  • More Doors Crew!
Re: removing strut
« Reply #34 on: 28 January 2012, 08:36 »
DO NOT CABLE TIE SPRINGS TOGETHER!  :shocked:  :shocked:  :shocked:
These things have enough tension in then to take ur face off if they let go, and ur face will more than lkely to be in they way when it will go!
I know we've all done stuff like that but seriously not worth it... "If a jobs a worth doing its worth doing proper!"  :smiley:
'02 3dr Tornado Red Gti 20v Turbo
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: removing strut
« Reply #35 on: 28 January 2012, 08:42 »
Not when you've spent this much time on it  :laugh:
Offline Chris.
Re: removing strut
« Reply #36 on: 28 January 2012, 12:56 »
Just loosen the bolt on the shaft.
Or the harder way and undo the 3 bolts on ball joint.
