Author Topic: removing strut  (Read 3739 times)
Offline mcgee9t2
Re: removing strut
« Reply #10 on: 21 January 2012, 17:55 »
ARB drop link undone?
yepp
Id undo the shaft and ler it slide out to allow the hub to slide right down.....nothing stopping it then.
and ah ok will give that a go, im guessing by "shaft" you mean driveshaft? if so how do you undo it? never had to take it off so wouldnt know and its too dark for me to go out and investigate now :D
Offline Chris.
Re: removing strut
« Reply #11 on: 21 January 2012, 17:56 »
Just unloosen the driveshaft nut but leave it on a few threads and push it through
Click For Build Thread
Offline mcgee9t2
Re: removing strut
« Reply #12 on: 21 January 2012, 18:00 »
so were the driveshaft mounts near the hub/wheel/break ect ect ect. there is a nut there, undo it so its almost off then does it just slide out?
is the metal that it attaches to in a U type shape or something ?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: removing strut
« Reply #13 on: 21 January 2012, 18:01 »
I had some spring compressors clamped on mine to help give a bit more room
Offline Chris.
Re: removing strut
« Reply #14 on: 21 January 2012, 18:06 »
The big 32mm but in the middle of the brake disc.
Offline mcgee9t2
Re: removing strut
« Reply #15 on: 21 January 2012, 18:11 »
ahh i see so will i have to take the nut compleatly off? or if i just loosen it will that give me enough leeway to knok everything further down and hopefully get the strut off?
or once its loosend will it somehow push through so its no longer attached?
Offline Chris.
Re: removing strut
« Reply #16 on: 21 January 2012, 18:18 »
Yeah, the shaft will push through the hub.  Loosening it, but not removing it MIGHT give you enough room.
Offline mcgee9t2
Re: removing strut
« Reply #17 on: 21 January 2012, 19:06 »
ah ok cheers, will give it a go tomoro :)
Offline houston
Re: removing strut
« Reply #18 on: 22 January 2012, 20:23 »
just a thought, are the bottom ball joints seperate to the wishbone like a mk3 or is it one piece? just it could be easier to undo the 2 bolts and pull the whole hub assembly down, obviously being careful.
or is it the arb keeping it up?
Offline dilbert
Re: removing strut
« Reply #19 on: 22 January 2012, 20:44 »
same as my3 mate, arb link bolts onto the side of the lower arm
mk4 golf 1.8 gti 20v
