Author Topic: AGU KILLS SPARKPLUGS  (Read 9419 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: AGU KILLS SPARKPLUGS
« Reply #20 on: 30 December 2011, 12:20 »
whilst your at it, get that crap castrol oil out of the car. Im am sure my AGU should be run on different oil, always use VW recommended oil from dealers or TPS.
Offline james2
  • No scammers please.
« Reply #21 on: 30 December 2011, 22:26 »
castrol oils good.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Mike671
« Reply #22 on: 30 December 2011, 22:47 »
Yes catrol oil is very good I work for a stealer and that's what we use except in cheap services we use quantum
Esplanade V.W Audi Mercedes And Smart Tech
Offline Hulmie
« Reply #23 on: 31 December 2011, 12:16 »
you may want to read the article in the maint section. and im 100% 0 40w is the incorrect oil for the engine.
1.8T:
For the 1.8T vw recommend fully synthetic 5W -30 oil. This should confirm to Vw 504 00 or 507 00. Castrol longlife III is the approved oil.
The 1.8T will take 4.35 litres of engine oil.
Weak spot:
 The 1.8T MUST use fully synthetic oil, and be changed at the correct service intervals, use of the wrong oil can cause the oil pick up to block up and the the oil pump to seize causing catastrophic loss of oil pressure and engine failure.
* NOTE * DO NOT USE Engine Flush!!
Read this : http://www.golfgtiforum.co.uk/index.php?topic=181271.0
1.8T oil filter part no: 06A115561B  £5 +VAT
Sump Plug: N90813202 £1.08 + VAT
There has been a lot of differant oils recomended by some VW dealers read this topic:
http://www.golfgtiforum.co.uk/index.php?topic=95412.0
I would strongly recommend a visit to your dealer to see which oil thay recommend for your 1.8T engine. (Give them your reg no and all your cars info will come up on the screen)
Some forum members use and recommend SYNTA GOLD 5W-40 fully synthetic which vw sell :
VW part no: AZGB 115 QLB 00 421 £24.36 +vat. This oil, oil filter ,sump plug comes to £35.79 all in from VW.
**EDIT**
Synta Gold - VW have replaced it with:
Quantum Platinum 5W-40 - £24.06/£27.67 for 5 litres
Part number - VZGB 115 QLB 00 551 036A
« Last Edit: 31 December 2011, 12:21 by Hulmie »
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #24 on: 31 December 2011, 13:59 »
Very fussy engines with oil.
All I would ever use on a 1.8T is Quantum Platinum 5W-40, stock power or 450+bhp.
 01455 617233
Offline james2
« Reply #25 on: 31 December 2011, 23:14 »
oil man on here said its good . Cost £60 .  :cry: but 0w 40 is better than 5w 40. If they had 5w 40 i would of bought it.   :smiley:
0w 40 castrol edge:
FOR PRESTIGE AND HIGH PERFORMANCE VEHICLES
Castrol’s best fully synthetic oil just got better
Castrol EDGE with Titanium Fluid Strength Technology is Castrol’s strongest and most advanced range of engine oils. Infused with liquid Titanium, its unique adaptive strength reduces metal to metal contact across a range of driving speeds, lowering friction and maximizing engine performance.
Benefits
Fully synthetic engine oil formulation that is specifically formulated to:
■maximizes short and long term engine performance
■sustains maximum performance for longer, even when under pressure
■improves engine efficiency, independently qualified
■reduces engine deposits to help maximize engine response
■exceed high performance standards set by premium car manufacturers including all FPV models, modern European and Japanese prestige vehicles
Applications
Castrol EDGE 0W40 A3/B4 gives you the confidence to demand maximum engine performance from today’s modern, higher revving sports cars and luxury vehicles requiring the lowest viscosity oils enabling the desired performance to be extracted.
Performance Levels
■API SN/CF
■SAE 0W-40
■ACEA A3/B4
■Approved for VW 502 00/ 505 00; BMW Longlife-01, Porsche A40 (refer to vehicle manual)
* THIS DATA SHEET DOES NOT CONSTITUTE A CONTRACT IN TERMS OF PROPERTIES
ITS GOT TO BE BETTER THAN THIS OIL IV BEEN USING FOR 2 YEARS. 10W 40
Castrol Magnatec combines Intelligent Molecules with part synthetic technology to instantly protect, from the moment you turn the key. It's Intelligent Molecules:
•Clings to your engine forming an extra layer that protects during warm-up and beyond
•Bonds to metal surfaces making engine parts more resistant to wear
•Provide protection for all driving conditions and styles.
Approvals & Specifications
•API SM/CF
•ACEA A3/B4
•VW 505.00
•MB-Approval 229.1
« Last Edit: 31 December 2011, 23:31 by james2 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #26 on: 01 January 2012, 00:24 »
Nothing wrong with 10w40, I use it with no problems
Offline golf-sib
  • Турботазик
« Reply #27 on: 01 January 2012, 00:53 »
10w40 here on all my cars, have used 5w30 on my polo no problem.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline james2
« Reply #28 on: 01 January 2012, 01:25 »
10W 40 is not fully synthetic, only part synthetic.   :sad: Use 5w 40 or 0w 40 . I blame the 10w 40 oil doing my turbo oil seals . castrol magnitec sucks, for are cars.
