Author Topic: AGU KILLS SPARKPLUGS  (Read 9409 times)
Offline james2
  • No scammers please.
« on: 26 December 2011, 23:22 »
Anyone know whats up with my car. Killed 2 sets of pulse plugs (the 10 bhp ones) and a set of nology silver .They end up white and blue ,like they got to hot.  :undecided: They are gap spot on .
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline barrym381
Offline james2
Re: AGU KILLS SPARKPLUGS
« Reply #2 on: 26 December 2011, 23:44 »
Thanks, but the plugs have died. I think it has something to do with there heat range. Pulse plugs lasted 3+ miles before going to limp mode or running on 2 cylinders and nology silver lasted 50+ miles.  :embarassed:
Offline barrym381
« Reply #3 on: 26 December 2011, 23:45 »
it killin all 4 plugs  :huh:
« Reply #4 on: 26 December 2011, 23:48 »
Have you tried a set of standard NGK's
Offline james2
« Reply #5 on: 26 December 2011, 23:55 »
it only kills about 2 of them . :angry: i think .  :undecided: And yeah ngk platinum are back in and are spot on. I dont get it. They all had the same gaps.  :undecided:
Offline Mike671
« Reply #6 on: 27 December 2011, 09:53 »
If the plugs that are dying are platinum tipped be careful gapping them because you can damage the coated electrode
Esplanade V.W Audi Mercedes And Smart Tech
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #7 on: 27 December 2011, 10:14 »
if its killing them it could be a sign of a weak spark, i.e coilpack going down which i wouldnt expect with an AGU. Get a set of standard NGK plugs or bosch super 4s. Never had a problem with either and alot of higher powered AGU's run these without problem.
Offline Hulmie
« Reply #8 on: 27 December 2011, 10:16 »
might also be worth checking the wiring going to the coilpacks where the plugs are burning out, you may have a break in the wiring and then plug not sparking as should. Then over time the AF mixture will combust under pressure. Are you noticing unburnt fuel out the exhaust, pops or bangs?
Offline gavgtiturbo
« Reply #9 on: 27 December 2011, 10:21 »
May sound a silly question but have you got the correct oil in as ive known this happen when some woman at my work filled hers up with the wrong stuff.
