Author Topic: AGU KILLS SPARKPLUGS  (Read 9416 times)
Offline houston
Re: AGU KILLS SPARKPLUGS
« Reply #10 on: 27 December 2011, 14:49 »
platinum plugs are long life and designed to go into engines that are built for them plugs, they are a crap conductor but last for 50k plus! thatll be why there burning out. i noticed the difference straight away on my mazda 3, wrong plugs were fitted and when i put the right plat plugs in it cured it, but it was noticeably slower.
stick to what vw recommend, once you get over 300bhp then you should start looking elsewhere
Offline golf-sib
  • Турботазик
« Reply #11 on: 27 December 2011, 23:26 »
I know what it is, have you checked your engine code it should say AUM as AGU's don't break, k tnx, bye  :smug:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline james2
  • No scammers please.
« Reply #12 on: 28 December 2011, 23:43 »
yeah its a AGU . I have the right oil, 0w 40 castrol edge ,just under max. Why do the plugs metal  turn blue and a bit of white soot. Iv gave up on uprated plugs .Is it because its had a remap and they over heat. Denso ik22 go black with soot, i thought they were for stage 1 map( but they never died).  :undecided:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline danny_p
« Reply #13 on: 28 December 2011, 23:52 »
heat ranges
all the VW's have gone bar 1.
Offline james2
« Reply #14 on: 29 December 2011, 00:39 »
That what i think. When r-tech tested pulse plugs and nology silver ,what did they test it on a standard engine. :undecided:
Offline littco
« Reply #15 on: 29 December 2011, 07:34 »
Is your car remapped? If so could be you're running lean and burning the plugs. Get it logged to see what's happening with the fuelling. My main concern wouldn't be the plugs but the cylinders , valves and rings melting.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #16 on: 29 December 2011, 08:23 »
I run IK22s on stage 2 with no problems
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #17 on: 29 December 2011, 17:56 »
Its worth getting the air fuel ratio checked out.
 01455 617233
Offline james2
« Reply #18 on: 29 December 2011, 23:12 »
I have no way of checking it. I know it leaks oil into intercooler, but dont smoke .But when theres to much ,on full boost it runs crap and a big cloud of blue smoke comes out. It hasnt done this with the nology plugs in .But i dont boot it .I have a month ago with ngk platinum and it pulls like a train ,gave a bike a good race from a set of lights. The NGK are perfect.  :undecided:
Offline RTechUK
« Reply #19 on: 29 December 2011, 23:23 »
Pop up in the new year and I will take a look for you if you want dude   :wink:
Nick
 01455 617233
