Author Topic: N75 Valves  (Read 6599 times)
Offline Yohan
N75 Valves
« on: 20 December 2011, 09:26 »
Hello,
Car Spec - 1.8T AMK, K04-023, Pipewerx 3" Downpipe c/w 200cell cat, Milltek 2.75" Cat-Back, SFS 3" TIP c/w Jetex Cone, Forge 007, FMIC, 4bar FPR, Samco Vacuum Hoses, Silicone Boost Hoses
I've been doing a lot of reading on these valves and need some feedback from tuners about them.
I had my car R-Tech'd earlier in the year and the map is fantastic, however one day it just lost it's boost spike and max boost.
I boost leak tested it to 25psi and there are NO leaks at all.
My car used to spike 24psi then hold 21/22psi across the range. Now it only makes and holds 19psi across the range.
However!
When I pull the N75 out of the TIP (i.e. the side of the valve that is used for bleeding air in to the tip) and plug the tip, then go for a drive, it makes and holds 22psi across the range.
I don't see how effectively creating a leak would make me more boost?
It's the standard N75 F valve and I'm just wondering if it's broken?
I'm waiting to borrow a friends to test it out.
« Last Edit: 20 December 2011, 10:18 by Yohan »
Offline The Doc
  • E63s Estate - Vito Sport
Re: N75 Valves
« Reply #1 on: 20 December 2011, 09:46 »
 :lipsrsealed:
Offline Yohan
Re: N75 Valves
« Reply #2 on: 20 December 2011, 10:17 »
 :shocked:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: N75 Valves
« Reply #3 on: 20 December 2011, 19:08 »
I have AMK engine in mine
I have just Got a New N75 from audi dealership, the F is revised now to one that ends in E..
full part number is; 06A 906 283E
Old part number is: 058 906 283F
(Notice the number at the start is now 06 (old F valve is 05)
Cost me about £37 quid
The revision was done recently
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: N75 Valves
« Reply #4 on: 20 December 2011, 19:53 »
my brand new F and then the E the dealers replaced it with leaked :angry:
Offline Yohan
Re: N75 Valves
« Reply #5 on: 20 December 2011, 20:20 »
Cheers guys.
Are these prone to leaking? Would it show up in a boost leak test?
My system can hold 25psi easy when I tested it.
Tonight I did a throttle body adaptation and then took it for a spin, not too much because it's icy but foot to the floor in 2nd and 3rd only saw a max of 17psi now.
I seem to be gradually loosing more and more boost
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: N75 Valves
« Reply #6 on: 20 December 2011, 20:56 »
do the suck test on it, I can't remember which pipes you need to try but you shouldn't be able to suck any air through two of the pipes
Offline Yohan
Re: N75 Valves
« Reply #7 on: 20 December 2011, 21:15 »
Any more info on this suck test?
Do I just take the valve off to try this?
jamie16v
Re: N75 Valves
« Reply #8 on: 20 December 2011, 21:32 »
its the two shorter pipes i think.. the longer one goes into the tip if i remember correctly..
Offline Yohan
Re: N75 Valves
« Reply #9 on: 20 December 2011, 21:34 »
Bottom one is boost from charge pipe
Shorter one goes to actuator
Longer one goes to tip
Do I block any when I do this test?
What should I be looking for?
