Author Topic: N75 Valves  (Read 6602 times)
Offline Yohan
Re: N75 Valves
« Reply #20 on: 20 December 2011, 22:53 »
Yup, no leaks. Only place air comes out is the oil filler.
Video 4 - Compressor Off @ 25psi
Video 5 - Compressor Off @ 25psi Tester Gauge
Video 6 - Compressor Off @ 25psi Inspection
« Last Edit: 20 December 2011, 22:55 by Yohan »
Offline Yohan
Re: N75 Valves
« Reply #21 on: 21 December 2011, 09:53 »
Would a slowly failing MAF cause such issues?
My g/s is down on what it should be as well.
Offline golf-sib
  • Турботазик
Re: N75 Valves
« Reply #22 on: 21 December 2011, 10:13 »
It can do, if it's on its way out things will slowly be getting worse, you tried cleaning the contacts on MAF and cleaning the sensor as well?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Yohan
Re: N75 Valves
« Reply #23 on: 21 December 2011, 10:21 »
Nope, haven't tackled the MAF yet as it's 2 months old so thought it couldn't be that.
Is cleaning the sensors recommended?
A friend is going to let me borrow his at the weekend so hopefully that will rule the MAF out.
I remember on his LCR though when it went duff it just lost more and more power but never threw a fault code.
Offline Yohan
Re: N75 Valves
« Reply #24 on: 21 December 2011, 10:26 »
Reply from Badger5 on Audi Sport
"badger5
    you should be able to blow thru the centre (boot in) port of the n75 and it should exit the long (tip) port.
    yours sounds blocked which is'nt good.. but this should create uncontrolled boost if when you blow into the ports nothing comes out..? "
Offline Yohan
Re: N75 Valves
« Reply #25 on: 22 December 2011, 10:28 »
Can anybody else confirm whether they can blow through the bottom of their N75 valve and feel the air exiting from the TIP port?
Offline golf-sib
  • Турботазик
Re: N75 Valves
« Reply #26 on: 22 December 2011, 10:48 »
I dont really do blow jobs.......
I'll see if I can give it a go tonight as I need to plumb the MBC in for up up up boost.
1.8T AGU..
R135
  24
Offline Yohan
Re: N75 Valves
« Reply #27 on: 22 December 2011, 15:03 »
Thanks...you saucy minx  :laugh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: N75 Valves
« Reply #28 on: 22 December 2011, 19:55 »
right I have my N75 here...
long pipe that goes to TIP - can't suck or blow through it
short pipes - can blow suck through these pipes
Offline golf-sib
  • Турботазик
Re: N75 Valves
« Reply #29 on: 22 December 2011, 21:49 »
Same result, I can blow and suck through both short pipes, but nothing through long one. When you blow through either short ones it blows out the other short one.
1.8T AGU..
R135
  24
