Author Topic: N75 Valves  (Read 6616 times)
jamie16v
Re: N75 Valves
« Reply #10 on: 20 December 2011, 21:37 »
no dont block any, you will be looking for leaks  :wink: when there is no power to the n75 it is in closed position.
Offline Yohan
Re: N75 Valves
« Reply #11 on: 20 December 2011, 21:40 »
At the risk of sounding stupid and creating more innuendo, I suck on the one that goes to the turbo (shorter one) and no air should come through cause the valve is closed?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: N75 Valves
« Reply #12 on: 20 December 2011, 21:49 »
got it wrong, you need to suck the longest pipe on the N75, you shouldn't be able to pull any air through
no more talk about sucking pipes now please :grin:
Offline Yohan
Re: N75 Valves
« Reply #13 on: 20 December 2011, 21:53 »
I feel dirty just talking about it...
Will report back soon.
Offline james2
  • No scammers please.
Re: N75 Valves
« Reply #14 on: 20 December 2011, 22:06 »
:lipsrsealed:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline golf-sib
  • Турботазик
Re: N75 Valves
« Reply #15 on: 20 December 2011, 22:27 »
Whack a MBC in and adjust accordingly till you hit the desired boost you had before?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Yohan
Re: N75 Valves
« Reply #16 on: 20 December 2011, 22:31 »
Right test complete.
Firstly tried to suck air through the longest pipe (TIP side) but couldn't, no air passing through. Also tried to blow air through it and couldn't either.
Out of interest sake I sucked/blew the bottom of the N75 valve (from charge pipe) and had the same result, no air passing either direction.
However, my MAP sensor is another story....
I went to check the plug was in properly and noticed a crack on it and there is a lot of flex on the plug
I took a video so hopefully it shows what I mean.
Could this be the reason I can only make 17psi boost instead of my usual 24psi spike/22psi held across the range?
The car is showing no fault codes.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: N75 Valves
« Reply #17 on: 20 December 2011, 22:42 »
On my spare one here I can blow/sucker through the the smaller pipes but not the TIP pipe
not sure about MAF, surely it would throw up a code?
Offline Yohan
Re: N75 Valves
« Reply #18 on: 20 December 2011, 22:45 »
MAP dude (cold side of intercooler) not MAF :) Like you say though I would've expected a code.
Interesting.
I can't blow or suck through the bottom pipe. The one that is connected to the chargepipe.
What does that mean?
Offline golf-sib
  • Турботазик
Re: N75 Valves
« Reply #19 on: 20 December 2011, 22:47 »
If map connectors where loose and the connection was lost, it'd store a fault surely, You have had it pressure tested to make sure there's no leaks?
1.8T AGU..
R135
  24
