Author Topic: OK what did i forget to do? RNS-510 + Mk6 GTI coding  (Read 16278 times)
Offline Snoopy
  • Moderator
  • Geoff.
« on: 03 December 2011, 17:19 »
A standard 2010 GTI with only factory options of xenons and sunroof.
Just tried to retrofit the RNS-510 and failed. :embarassed:
After installing the satnav i tried to code it as shown in this thread
http://www.golfgtiforum.co.uk/index.php?topic=152441.0
I did, i think, as instructed in that thread.
I ticked the navigation in the can gateway instalation list and saved it.
Then went into controler 37 navigation
NOTE BELOW ARE NOT MY SCREEN SHOTS BUT THE ONES FROM THE HOW TOO..
Byte 0 bit 1, 2 and 3 (all not ticked, (maybe the aux one should be?).
Byte 1 sound system not installed
Byte 2 04 front and rear speakers installed
Byte 3 unticked mic diagnostics as was ticked.
Byte 4 04 speaker monitoring front and rear
Byte 5 equalisation linear
Byte 7 bit 1,2,3 & 7 all unticked. 5-6 premium selected.
Then clicked 'do it'
(please check i sellected the correct ones for the mk6 please.  :embarassed: )
Autoscan with VCDS then gave me these results.
Saturday,03,December,2011,14:27:39:43339
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
VIN: ############
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Sporadic communication error 1000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH14---    Serial number:
   Coding: 0403000C18070060
   Shop #: WSC 01357 011 00200
   VCID: E7D62531AFF6
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 163B600D092B0003680F06EC90220081340800
   VCID: 78F4F64D7248
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_Climatronic_VW36.rod
   VCID: 7DFAE7595D6A
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 48180A3E9025F1C0448800803400092443550488732D8960648000200000
   VCID: 32600465D4B4
   Part No: 1K2 955 119 F
   Component: Wischer 19011  21  0512
   Coding: 009795
   Part No: 1K0 955 559 AH
   Component: RLS 250110 05  54  0402
   Coding: 0330AD
   Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA34V4V
   Coding: 00003135
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   VCID: 3B7E294103FE
   Driver's Airbag Crash Sensor:
   Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME1534144FZZZU
   Passenger Side Airbag Crash Sensor:
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME3167444EZZZ.
   Driver's Rear Airbag Crash Sensor:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME0E354A00ZZZR
   Passenger's Rear Airbag Crash Sensor:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME0E004844ZZZQ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           056 0111
   Coding: 0000502
   VCID: 78F4F64D7248
   Part No: 5K0 959 542
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K6 920 970 D    HW: 5K6 920 970 D
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 470F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 356A3F7925DA
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 220110F2001754
   Coding: E9817F06400212000003
   VCID: 69D2A30939E2
3 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 12089 km
                    Time Indication: 0
                    Date: 2020.14.27
                    Time: 12:10:47
01044 - Control Module Incorrectly Coded
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 13
                    Mileage: 12089 km
                    Time Indication: 0
                    Date: 2020.14.27
                    Time: 13:12:47
« Last Edit: 03 December 2011, 18:57 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline Snoopy
  • Moderator
  • Geoff.
Re: OK what did i forget to do? RNS-510 + Mk6 GTI coding
« Reply #1 on: 03 December 2011, 17:19 »
03272 - Control Module for Audio Interface
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 12089 km
                    Time Indication: 0
                    Date: 2020.14.27
                    Time: 11:59:21
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EAD05C05BCE4
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7667755703
   Coding: 010000
   VCID: 2648E835E87C
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
 Part No SW: 1T0 035 680 F    HW: 1T0 035 680 F
   Component: RNS-MID       H06 3970
   Revision: AB001001    Serial number: VWZ6Z7L6153021
   Coding: 00000400040000A00006
   Shop #: WSC 00066 000 00000
   ASAM Dataset: ------------------------- ------
   VCID: 31620B69D1B2
4 Faults Found:
01523 - Microphone for Telephone (R38)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 7
                    Reset counter: 45
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 0 km
                    Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 45
                    Mileage: 24 km
                    Time Indication: 0
                    Date: 2001.14.17
                    Time: 15:58:57
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 0 km
                    Time Indication: 0
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2140
   Coding: 0000692
   VCID: 336E01612BAE
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 31620B69D1B2
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Component: Tuer-SG         009 2114
   Coding: 0000692
   VCID: 32600465D4B4
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1443164
   VCID: 346C027D2EA0
   Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   VCID: 31620B69D1B2
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 7
                    Reset counter: 45
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 45
                    Mileage: 24 km
                    Time Indication: 0
                    Date: 2001.14.17
                    Time: 15:58:57
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 0 km
                    Time Indication: 0
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 346C027D2EA0
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 356A3F7925DA
End   ---------------------------------------------------------------------
Im guessing from the scan i have missed something.  :sad:
« Last Edit: 03 December 2011, 17:21 by Snoopy »
Current Garage:
Offline Belix
« Reply #2 on: 03 December 2011, 17:41 »
media player is normally the MDI kit IIRC. Do you have that installed?
Will check my options under 37 and come back.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 03 December 2011, 18:05 »
Yes i have the MDI & Aux input as they are standard fit in England.
Current Garage:
Offline p3asa
« Reply #4 on: 03 December 2011, 18:37 »
Snoopy it must be something obvious as I had to borrow Vag.com so didn't know my way around it and it literally took me 5 minutes from plugging the cable into the car and i'm not that computer literate.
From what I remember in Byte 0 you need to tell it you have MDI.
In Byte 7 bit 0 you need to tell it you have the Multi Function Steering Wheel.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 03 December 2011, 18:55 »
I noted the setting for the RCD310 before i started.
Byte 0 bit 1 was ticked.
Byte 1 bit 0-7 00sound system not installed
byte 3 bit 0 stop press buttons (not ticked)
         bit 1 telephone prep (not ticked)
         bit 6 backup camera (not ticked)
Byte 5 bit 0-7 03 treble speakers monitored
So i was not sure if quick buttons for the wheel should be selected or not  :undecided:
Current Garage:
Offline Belix
« Reply #6 on: 03 December 2011, 19:13 »
mine -
byte 0 - Aux input monitoring ticked, other two not
byte 1 - 00 no sound sstem installed
byte 2 - 04 4 speaker channels
byte 3 - microsphone diagnostics ticked, no tick for backup camera...yet
byte 4 - 04 Speaker monitoring
byte 5 - 00 Eualisation liner
byte 6 - 00
byte 7 - nothing ticked even with MFSW, except bit 7 (communication instrument cluster etc)
byte 8 - 00 - no ticks
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #7 on: 03 December 2011, 20:30 »
Thank you .  :smiley:
Darren said to also try changing byte 7.
Changed  Byte 7
Bit 0 Shart press steering buttons installed ticked
bit 7 bapinstrument cluster  protocol ticked
Did a reset of the satnav <> + star  (did not seem to do anything but must have done something after holding it for 20 seconds)
Then cleared fault codes.
Now after a few more trys left with.
   VCID: 69D2A30939E2
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 45
                    Mileage: 12089 km
                    Time Indication: 0
                    Date: 2020.14.27
                    Time: 12:10:47
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 13
                    Mileage: 12089 km
                    Time Indication: 0
                    Date: 2020.14.27
                    Time: 13:12:47
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 12089 km
                    Time Indication: 0
                    Date: 2020.14.27
                    Time: 11:59:21
   Coding: 010000
   VCID: 2648E835E87C
« Last Edit: 03 December 2011, 20:33 by Snoopy »
Current Garage:
Offline mortygt140
« Reply #8 on: 03 December 2011, 21:40 »
Geoff if the unit did not reset i.e turn off and back on usually takes around 20-30 seconds then its not reset,
Press < > together then while holding them press the star button not altogether at the same time.
It seems the Media In isn't speaking to the RNS you may need to just check the blue plug on the RNS is properly seated.
Darren
Offline mortygt140
« Reply #9 on: 03 December 2011, 21:53 »
Clear the faults on the gateway aswell mate,
Ive had a look at both our gateways and navigations has both our cars are similar...I cannot make anything out that is untowards.
Darren
