Author Topic: OK what did i forget to do? RNS-510 + Mk6 GTI coding  (Read 16277 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: OK what did i forget to do? RNS-510 + Mk6 GTI coding
« Reply #10 on: 03 December 2011, 22:01 »
Thanks Darren.
I have tried unpluging and plugging it all back in just now incase this was the issue.
I recoded everything. Tried a reset(guess it did not work)
It then came up with the same 2 issues when i scanned, As the other faults cleared the last time i thought maybe it had reset, I guess not.
I Will try it again in the morning.
Thanks for the help.
Geoff.
« Last Edit: 03 December 2011, 22:06 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline mortygt140
« Reply #11 on: 03 December 2011, 22:48 »
Geoff if its anything to do with the RNS510 send it straight back buddy, Ill change it asap. seems to be the MDI thats not communicating.
Is the MDI actually working? is the RNS fully working?? do you have the nav and audio info in the highline display?
Darren
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #12 on: 03 December 2011, 23:09 »
Yes MDI is working as its been playing a memory stick most the day while ive been trying to sort it.
Once it did not see it at first but turning the satnav off then on and it was fine.
Took awhile to find a satalite after first install for some reason, it said my current location was a house number and street in dagenham i guess that was were it was powered up last.
Nav info was in the display when i set a destination but has been since i first tried to program it.
I scanned the car before i started to install the RNS-510 and it was all OK,
I regular scan the car every 3 months or so and have not seen an MDI issue previously.
I am wondering if the CAN gateway is saving properly? As i have read it sometimes does not unless you change the workshop code?
(I have the latest version of VCDS so maybe thats not an issue?)
Or/and
If i need to update the MDI software as it will be Feb 2010 spec were the satnav is June 2011
« Last Edit: 03 December 2011, 23:15 by Snoopy »
Current Garage:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #13 on: 03 December 2011, 23:19 »
Heres the scan from this morning before i did the satnav change if that helps.
Saturday,03,December,2011,11:47:38:43339
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
VIN: #######################
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH14---    Serial number:
   Coding: 0403000C18070060
   Shop #: WSC 01357 011 00200
   VCID: E7D62531AFF6
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 163B600D092B0003680F06EC90220081340800
   VCID: 78F4F64D7248
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_Climatronic_VW36.rod
   VCID: 7DFAE7595D6A
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 48180A3E9025F1C0448800803400092443550488732D8960648000200000
   VCID: 32600465D4B4
   Part No: 1K2 955 119 F
   Component: Wischer 19011  21  0512
   Coding: 009795
   Part No: 1K0 955 559 AH
   Component: RLS 250110 05  54  0402
   Coding: 0330AD
   Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA34V4V
   Coding: 00003135
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   VCID: 3B7E294103FE
   Driver's Airbag Crash Sensor:
   Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME1534144FZZZU
   Passenger Side Airbag Crash Sensor:
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME3167444EZZZ.
   Driver's Rear Airbag Crash Sensor:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME0E354A00ZZZR
   Passenger's Rear Airbag Crash Sensor:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME0E004844ZZZQ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           056 0111
   Coding: 0000502
   VCID: 78F4F64D7248
   Part No: 5K0 959 542
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K6 920 970 D    HW: 5K6 920 970 D
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 470F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 356A3F7925DA
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 220110F2001754
   Coding: E9817F06000212000003
   VCID: 69D2A30939E2
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EAD05C05BCE4
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7667755703
   Coding: 010000
   VCID: 2648E835E87C
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2140
   Coding: 0000692
   VCID: 336E01612BAE
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 31620B69D1B2
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Component: Tuer-SG         009 2114
   Coding: 0000692
   VCID: 32600465D4B4
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1443164
   VCID: 346C027D2EA0
   Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000022
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K8011304
   Coding: 0100040004
   VCID: 65CAAF39D5FA
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 346C027D2EA0
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 356A3F7925DA
End   ---------------------------------------------------------------------
Current Garage:
Offline Belix
« Reply #14 on: 04 December 2011, 09:39 »
yeah, first track of satellite seems to take a while but works pretty quick thereafter.
Offline Belix
« Reply #15 on: 04 December 2011, 09:49 »
I'm having a memory of a fault I had when retrofitting mine.
Check whether you have "CD-Changer/iPod/USB Connection Monitoring active" enabled. You might try disabling that and then re-booting the RNS. It is not needed for the MDI to work, and it got rid of my error.
« Last Edit: 04 December 2011, 09:51 by Belix »
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #16 on: 04 December 2011, 11:47 »
Removed the RNS-510 this morning.
Re-Installed the RCD-310
Set the coding back to the RCD-310
Cleared all fault codes.
Ran a VCDS auto scan
All results OK  :smiley:
Refitted the RNS-510
Coded exactly the same as i did previously.
Tried to reboot the RNS-510 but failed. Operator error i suspect  :embarassed: (does not seem to do it, do i have to be in some special menu? )
Ran VCDS auto scan
All results OK.  :smiley: :cool:
RNS-510 during the scan turned itself on quietly then at the end of the scan did not turn itself off i had to do it, odd.
I now pray it stays all OK from now on. :smiley:
« Last Edit: 04 December 2011, 12:42 by Snoopy »
Current Garage:
Offline mortygt140
« Reply #17 on: 04 December 2011, 13:30 »
well done geoff we'll make a master vagcomer out of you yet :smiley: any further problems just let me know
darren
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #18 on: 04 December 2011, 13:36 »
Thanks Darren,
To reboot the RNS-510 do i have to have it in any special menu or have some option turned on to allow it to do it?
I had it on the radio and held down the < and > buttons then pressed the * and held them all down for over 2 minutes by my watch nothing happened.
Tried it in MDI still did not do it.
Tried it after pressing the setup menu button nothing happened
Tried it as it booted up said unavilable at this time or somthing like that.
I have read this morning some say its the eject button not the * button. Tried that still nothing.
 :sad:
The Mk6 is more or less going to be off the raod till mid March (as i have a winter car for the snow/ice/grit) so i doubt it will throw up any faults till its back on the road properly at the end of March if it does give any faults, fingers crossed.
Thanks for all the help everyone.
Geoff.
« Last Edit: 04 December 2011, 13:42 by Snoopy »
Current Garage:
Offline mortygt140
« Reply #19 on: 04 December 2011, 13:42 »
Ive been having problems lately with rebooting the late C and F version, I sort of hold down < > then a quick press of the star button or keep pressing the 3 buttons together it will reboot eventually but seems to be hit and miss, like VW have made it so it harder to reboot :angry:
Darren
