Author Topic: Devils Own / 100% water or X% methanol?  (Read 15038 times)
Offline Dave_IOW
Re: Devils Own / 100% water or X% methanol?
« Reply #40 on: 12 December 2011, 20:08 »
I fitted it there Dave because that were nick got his he got his nos next to it to. Going by devils guide intake seems the best location for cooling which is what nick is using his for as he only runs his on water
No probs bud, horses for courses pal  :afro:
Im neither knocking it or praising it, just need to decide whats best for me   :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #41 on: 12 December 2011, 21:56 »
yeah its no problem mate i just went with what nick said he said to fit it there
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline Dave_IOW
« Reply #42 on: 12 December 2011, 21:58 »
The only thing i can see against it is that it doesnt look like it will inject equally into all cylinders..
Offline danny_p
« Reply #43 on: 12 December 2011, 23:52 »
youd be suprised how turbulance in the airflow will smash the liquid you inject about and spread it allover the place
all the VW's have gone bar 1.
Offline Dave_IOW
« Reply #44 on: 12 December 2011, 23:57 »
You think judging by the image of said manifold, that it would be an equal(-ish) concentration?
« Reply #45 on: 13 December 2011, 10:22 »
With how fine it mists I wouldnt of thought it would be an issue
Offline shaft69
« Reply #46 on: 13 December 2011, 11:19 »
Only time rally seen valve in manifold if has 4 valves for each cyl.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline danny_p
« Reply #47 on: 13 December 2011, 20:28 »
i think it's be fine.
air in intake systems goes pritty damb fast and it should be a fine mist so it's going to get dragged round where it needs to go.
looked into something simlar at work breifly and we ended up makeing a transparent replica manifodl out of resin and useign a red dye and some fast cameras
if you have a continus flow though each runner you do get unequal disttrobution  if you have a pulseing flow it all evens out enough.
if it was a motorsport engine things would be done diffrently but on a modifyed fast road engine it's fine imo
Offline Dave_IOW
« Reply #48 on: 13 December 2011, 20:48 »
Thanks  :afro:
