Author Topic: Devils Own / 100% water or X% methanol?  (Read 15235 times)
Offline Toby
  • Car - less
Re: Devils Own / 100% water or X% methanol?
« Reply #20 on: 04 December 2011, 12:08 »
ooooh i see!! worth it?
Currently down under
Offline Dave_IOW
« Reply #21 on: 04 December 2011, 12:17 »
Hopefully  :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Toby
  • Car - less
« Reply #22 on: 04 December 2011, 12:24 »
i guess for big power!! but tbh, im happy with my 225bhp atm! there is soooo much plod around! any more poke ill be colecting point's!
so its on the hunt for lows, looks and rims!  :lipsrsealed:
Offline shaft69
« Reply #23 on: 04 December 2011, 14:06 »
Just purchased labonte motorsport kit from states comes with throttle housing spacer for mk4 to screw jet into, suppose to be brilliant kit they supply snow with there water inj components.
I see yu got it off a guy from vortex. Good luck with royal mail!! I bought some conrods from a guy from vortex, they took over 2 months to arrive they took 2 days to get to England then they lost for 2 months. Hope it goes better for you mate!  :smiley:
Went back on deal bought new AEM progressive system instead with 1gal tank.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
jamie16v
« Reply #24 on: 07 December 2011, 11:40 »
i`m not going to bother going down this route as i see it as an unsafe method, if it runs out and youre running massive advance thien i think its melty melty time..
i`m seriously thinking of saving for a nitrous oxide kit though  :evil:
Offline golf-sib
  • Турботазик
« Reply #25 on: 07 December 2011, 12:29 »
Golf has knock sensors, you can tune with meth with tolarance to the knock sensor, so once you run out of meth it will detect it. If you was tuning by ear by listening to detonation without the knock sensors in play then it becomes the scenario you are saying above.
I remember nick said the stock knocks sensors aren't great, so how much of an advance you will get with the knock sensors on, only he will tell you from all the R&D he has done on his own car and other custom maps, so send a phone call his way.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Dave_IOW
« Reply #26 on: 07 December 2011, 19:13 »
Yeah i wont be going crazy with it, just a bit more power but mainly its for safety.
Not sure whether to keep jet there or further back up the system like tapping the jet into the silicone intercooler - TB hose.
Arrived today;
Offline danny_p
« Reply #27 on: 08 December 2011, 21:29 »
size your tanks right and it dosent run out,  it comes into it's own with standallone managment tho where you have extra programable inputs and outputs.
with the s3 it's running port methanol injection and a water misters in the plenum.
i have the tank level sensor connected up to the ecu so it dosent go into mental mode without sufficent juice,  water consumption works out to be about 25% that of fuel so now combined water and window wash tank is 15ltrs,  meth tanks are 15ltrs each   both under car as i don't liek the idea of neat meth in the passinger cell.
you'd never guess  i make 15ltr stainless tanks  at work occasionaly  :smiley:
all the VW's have gone bar 1.
Offline shaft69
« Reply #28 on: 11 December 2011, 20:47 »
Arrived today;
Fitting mine soon going to put my jets one in intake hose, poss one spraying cooler itself. Not sure where to fit bottle, if under bonnet and using only water in this weather freeze so boot's looking more likely. Not sure is will freeze with 25% meth/75% water, not sure on freezing point of meth will have to investigate.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Dave_IOW
« Reply #29 on: 11 December 2011, 20:58 »
Will look forward to see what happens with you install then  :smiley:
