Author Topic: Fitting pd 130/150 middle pipe to 1.8t aum. Updated with problem.  (Read 1990 times)
Offline Big Tone
In the parts catalog it shows two sleeves to use when fitting. Presume these are required? And are not part of the standard set up?
« Last Edit: 25 December 2011, 12:31 by Big Tone »
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline sprout99
Re: Fitting pd 130/150 middle pipe to 1.8t aum.
« Reply #1 on: 17 November 2011, 11:40 »
yeah
one to joint to cat and one to back box before it goes over axle
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline houston
« Reply #2 on: 17 November 2011, 16:47 »
the sleeves are part of oe system so if you havent touched your exhaust then you should already have them, you can reuse the cat to middle pipe sleeve, but if its not a genuine exhaust pipe youve bought then you will need a u clamp to hold the other end.
buy new coach bolts and the old sleeves will be fine to use again. but note they are slightly different sized sleeves so dont mix em up
Offline Big Tone
« Reply #3 on: 17 November 2011, 19:18 »
Top man, saved me some money there.
Offline Big Tone
« Reply #4 on: 25 December 2011, 12:30 »
Just gone to do this and there is no sleeve between the middle box and back box. WTF?
Exhaust Is factory fitted.
Time for some chopping I presume.
Offline Mike671
You got it  :smiley:
Esplanade V.W Audi Mercedes And Smart Tech
Offline thatwillis
Yeah i noticed this too I haven't got round to fitting mine yet. Get yours from uni part? Some pics would be good if you get the chance  :smiley:
Offline Big Tone
Yup bud, unipart.
Will take some pics, thinking about waiting for my downpipe and decat then ill just do it all in one go.
Offline scarr89
  • Mk4 Golf, DERV FTW!
May I ask why you would want to do this? What is the differences and potential benefits if any?  :smiley:
Offline houston
no sleeve? maybe its an agu thing. what was on to join the pipes?
