Author Topic: Fitting pd 130/150 middle pipe to 1.8t aum. Updated with problem.  (Read 1997 times)
Offline Big Tone
Re: Fitting pd 130/150 middle pipe to 1.8t aum. Updated with problem.
« Reply #10 on: 27 December 2011, 14:46 »
no sleeve? maybe its an agu thing. what was on to join the pipes?
No joint pal, straight from middle silencer to back box
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline houston
« Reply #11 on: 27 December 2011, 14:55 »
there has to be a joint, vw didnt fit it one piece, should be a sleeve just before the centre bracket and a one just after the bend before it goes over the rear beam
if not it looks like someone has welded it up in the past
Offline Steve_PD
« Reply #12 on: 27 December 2011, 16:13 »
Mine was one piece from the cat back
Offline houston
« Reply #13 on: 27 December 2011, 18:18 »
must have been welded in place surely, its a pig to get the back box off without cutting it as it is without the extra length. unless vw changed there design and they fit the exhaust before the rear beam
sounds like youll have to line your new pipe up to the exhaust fitted and do some cutting, and a trip to vw to buy the sleeve if you dont fancy u clamps (hateful things)
Offline Steve_PD
« Reply #14 on: 27 December 2011, 18:33 »
They wouldnt weld it in place, they'd never weld the top half.
To get it out without cutting take the rear beam bolts out and jack the car up a more give you more room.
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #15 on: 27 December 2011, 18:38 »
Just get a set of pipe cutters on it. When I did mine on my AUQ Cupra the middle section was sleeved front and back but the new pd150 middle pipe slotted over the cat with a U clamp and simply sleeved where it met the back box. I have seen Golfs before with both the middle and rear boxes all one peice.
Offline golf-sib
  • Турботазик
« Reply #16 on: 27 December 2011, 23:19 »
It's one piece on my AGU as well was well annoyed to find this out a few weeks back as I couldn't find my axle stands and really couldn't be bothered to take a chance chopping it with the widow maker.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
